Suspended
- 2 May 2011
- Woking
Unlucky for living in an area with rubbish planning officers then.
Isn't that everywhere?
hopefully it doesn't come to that, but good to know.
Cheers @dlockers
second image to keep you happy:
to scalelooks lovely. Colour me jealous. 20 solar panels as well... is that to scale or just a generic "will have solar panels". because that must be a massive sized house to fit 20 panels on one side of the roof!. I hope you get it. we had planning for 2 extensions on our pad and both times it was nail biting but all came good in the end.
1. Severely reduced daylight to neighbouring properties impacting both inside the properties on both ground and upper levels and well as the garden. The properties that back on to the Kingston By pass are already light deprived by large trees at the end of the gardens.
2. None of the properties that back on to the Kingston Bypass 'on the straight' part of XXX have double height rear extensions. Going ahead with this proposal would be out of sync with neighbouring properties and would be over developed for the road. Approving a double height rear extension would set a precedent for other properties to be over developed and suffer light deprivation and reduced quality of life.
To add to this, this neighbour did not object to ANY other planning application on my roadIn addition to the above, the impact of such a significant development will affect xxxx residents with increased volume of traffic and construction vehicles. We are already impacted withthe number of cars parking in XXXX to commute to London and use local shops/services. Increased vans and construction vehicles are hazardous particularly with large numbers of young families and elderly residents. Also, XXXX is a main route for children walking to Hinchley Wood Primary School and more vehicles parking on the road and pavements will compromise their safety.
This house is two doors away and it's physically impossible for me to block their lightOur property (#xx) would suffer a significant loss of daylight to the rear/garden and this would also result in a significantly obstructed view from our garden - so I can only imagine the properties even closer would be much more adversely impacted.
My direct neighbour knows I live alone and have 1 car but yet they moan about this. They have a 4 bed house and park on the street so it's OK for them but not for me. Thankfully they've sold up and I'm glad.The plan proposes to double the size of XXX from 130 to 260 square metres, a development which is totally out of keeping with neighbouring properties. The most recent Elmbridge Planning Consultation for new homes has a clear focus on 3-4 bedroomed homes. This proposed over development is for a 5 bedroomed house and does not consider the parking for 5+cars given that there may be 10 people in residence.
5. I also have a concern relating to point 3.18 of the Design and Access Statement: "The alternative for the applicant would be a Permitted Development scheme. The PD scheme that would be most cost effective for the applicant is set out below. Whilst a Certificate of Lawfulness has not been sought for this fallback position, the scheme has been checked against the Ministry of Housing Communities & Local Government Permitted Development Rights for Householders -Technical Guidance, which officers will be familiar with. As such there is no need or requirement to seek a Certificate of Lawfulness in this instance. "This comes across as somewhat threatening and appears to read as 'if the planning permission is not granted then the occupier of XXXX will have a legal right to go ahead with a maximum size build under Permitted Development'. If this is the case, this would appear to negate the purpose of the planning process we are currently working through.
address
Cedar? It ages that way.localish architect built an overboarded house which was initially a nice auburn/brownish colour, vertical planks, and after 6 years this now looks like a grey block-house,
they can't be short of a bob , attached stables, too, but my prospective input on a near neighbour doing similar would be adverse.
I've never investigated cost saving from the building style, but would like to know lifetime 15/20 year cost.
Good spot! Thank you very much!I think you've left your address in your last quote
We will contract in a builder for the primary structure and I will manage the finishing.Ignore the nimby types, they've got nothing else better to do than complain. 99% (at least) of them will have absolutely no standing in terms of planning rules and will totally be bemusing personal opinions of someone who has googled planning regs and interpreted them in a way they deem suits their rhetoric. Nobody has a right to a view for example, although there are rights to light, but seems you don't affect anyone's light.
OP - looks like a decent build - are you self-building?
gateway's
