Does anyone have any experience of the Gigabyte 7900 XT Gaming OC?
Been offered it as a RMA replacement for a RX6950XT reference (or a partial refund, or a 7900 GRE when in stock).
The 6950XT was near silent, but I can't find much about the Gigabyte 7900XT and my only experience of a Gigabyte card was a Radeon 580 which sounded like Henry Hoover being attacked by a swarm of bees which is putting me off. I know the performance is an upgrade over the 6950 and 7900 GRE that has been offered, but I'm not sure I'm interested if it's going to be loud and hot.
Which RX 7900 XT to BUY and AVOID?! | 11 Cards Compared! Asus, Asrock, Sapphire, Powercolor, XFX
Which is THE BEST RX 7900 XT? Let's compare the VRMs, Power Limits and Cooling performance of these different models! Join the O!verclock Club to support me...
Skipping through it, there's some comparisons in there.
It says it's on par with the Pulse cooler, I've got an xtx Pulse-it's decent.
Don't know what size your 6950 was, but these are big GPUs and the gigabyte support bracket goes past the length of the GPU in case that's an issue(you need to install some kind of support bracket).
More vram on the 79 would push me thataway as you can undervolt/under clock quite a bit to quieten the card=less heat/noise output.
