- 25 Sep 2012
I've got the tefal ingenuity range with the clip kn handles they've held up well
There's about 3 different kinds of coating they use check with the shopstaff /google the normal one is crao but there is one that's rated for metal utensils that's what I use
Somehow I've never looked up how to use a stainless steel pan until your comment, every time I've used one I've done it wrongStainless steel I clean it with metal scourers. The way to make it non-stick when in use is simply do the following.
1 - Heat it hot with nothing on it, it will open up the pores in the metal
2 - Add oil then lower the heat
As the pores closes due to the temperature dropping, it makes the non-stick layer. Now you are reading to cook. Even an egg won't stick.
Binned my last non-stick pan over a decade ago now, convinced they only exist to keep selling disposable crap to people over and over again.I gave up on non-stick a long time ago. For most things now I use uncoated stainless steel. I do have one non-stick frying pan for those awkward things that stick like glue, but only really to save the food. Stainless steel is really easy to clean even if the food is stuck.
Ahh I was playing on your nameThere's about 3 different kinds of coating they use check with the shopstaff /google the normal one is crao but there is one that's rated for metal utensils that's what I use
Ahh I was playing on your name![]()
Tefal suxAhh I was playing on your name![]()
How do you find the non stick wok does it brown nicely?Yeah I have a Tefal Wok with the better non-stick coating that’s safe for metal utensils.
I have to say it’s as tough as old boots! Really good non-stick coating that has lasted extremely well.
This one
(BAD PURECHASE) these are hard anodized .. but the concentric ridges, are crummy and just allow fat to catch in the dips and are hard to clean
Circulon TOTAL Non Stick System
Circulon features the technologically advanced TOTAL Nonstick System which combines a relaxed Hi-Low wave technology with one of the most nonstick coatings available.
Food cooks and releases on the entire surface of the pan. But raised circles on the 'Hi' area allow a fraction of the cooking surface to take all of the abuse of utensils, protecting the majority of the cooking surface on the 'Low' area from abrasion. The result of this has been enhanced cooking performance and nonstick durability.
eg
Woks must be heated to very high temperatures—usually between 200 and 315 degrees. You'll need a burner with a high BTU rating to get the job done right. Most home stoves have BTU ratings between 10,000 and 20,000 BTUs.
Wok burners start at around 30,000 BTUs and go up from there. The higher the BTU rating, the more expensive the burner will be. However, it's worth investing in a quality burner that will last years.
That's frying pan though.as said - wok temperature incompatible with non-stick on a decent gas hob
