There will be signs it's been tampered with and at that point they will just send you the card back saying "Sorry you messed around with it".
Also as Alt0153 said, There are other issues besides the 1 fan, A 108'c hotspot temp is not normal for a watercooled card, It means there's something wrong either with the pump or it's not seated correctly.
pretty much none of them allow you to do this, does it have a warranty void sticker on screws anywhere? i dont see why you are so willing to take apart a 2k gpu and risk is still being ****** than just send it back for replacement under warrantyFor those who have this card or have owned MSI GPUs - do they not allow the cooler to be removed to apply paste or to replace the stock fans or thermal pads? Wouldn't this fall under maintannce?
Isn't that because the fan isn't working?
I have the same 4090 Suprim X Liquid and barely see temps higher than 50c.For those who have this card or have owned MSI GPUs - do they not allow the cooler to be removed to apply paste or to replace the stock fans or thermal pads? Wouldn't this fall under maintannce?
Hello everyone.
The issue is now fixed.
It was an issue with the rear block retention bracket, it was causing uneven distribution of the CPU block, just swapped it out and not exceeding 60 now even on full whack.
Thank you to everyone for their help.
No pictures were taken.
