- 13 Jun 2012
As per title, thank you.
Is that JDEC rated or is that XMP/EXPO?TEAMGROUP Elite DDR5 32GB Kit (2x16GB) 6400MHz PC5-51200 CL52 Non-ECC Unbuffered UDIMM 288 Pin PC Computer Desktop Memory Module Ram Supports Intel & AMD TED532G6400C52DC01
YES it is:Is that JDEC rated or is that XMP/EXPO?
OP wants JDEC speeds at 1.1v.
OP, you’re going to struggle to find JDEC speeds that high at 1.1v.
That's the price of dropping to 1.1v. it's still only 16.25ns latency though.CL52![]()
Someone should benchmark the kitThat's the price of dropping to 1.1v. it's still only 16.25ns latency though.
Would be interesting to see the difference, it’s probably just Hynix A-die with the timings increased so the voltage can be dropped down.Someone should benchmark the kit
They appear to be listed as compatible with Z790 refresh, so I wonder if only the newer Z790 boards have the profiles available to configure these correctly, though 6000 says compatible with 600 and 700 series and I thought they had 5600 as the max speed when these were released.Is that JDEC rated or is that XMP/EXPO?
Might be enabled with a new BIOS?They appear to be listed as compatible with Z790 refresh, so I wonder if only the newer Z790 boards have the profiles available to configure these correctly, though 6000 says compatible with 600 and 700 series and I thought they had 5600 as the max speed when these were released.
The RAM will probably default to 4800 for both AMD and Intel. It's unlikely that AMD/Intel will add any profiles for current hardware.They appear to be listed as compatible with Z790 refresh, so I wonder if only the newer Z790 boards have the profiles available to configure these correctly, though 6000 says compatible with 600 and 700 series and I thought they had 5600 as the max speed when these were released.
