Yep! C850, LOVE it! Mine is a tasty spec Seasonic in a posh dress, has a zero rpm fan mode, and even with that disabled, I've yet to hear the fan. 10 Year warranty, 80+ Gold, fully modular, and the cables come in a posh purple washbagHas anyone got one of these what ate they like ?
You only got it for the purple bagYep! C850, LOVE it! Mine is a tasty spec Seasonic in a posh dress, has a zero rpm fan mode, and even with that disabled, I've yet to hear the fan. 10 Year warranty, 80+ Gold, fully modular, and the cables come in a posh purple washbag
You only got it for the purple bag![]()
Yep! It's living it's best life in the box that the PSU came in, which is living in a bigger box the case came in, along with the other boxes, so basically my cases box, is like a block of flats for all the PC partsThe purple bag is a key part of the total package!
You can, erm, put your unused cables in it and then, umm, put it back in the box and then, if you're like me, put that in a bigger box in your loft.
(Got a C650, very pleased with it)
If you have 3 8 pins then you're sharing the load between 2 cables anyway, so you'll probably find it is fine, but if you can conveniently avoid doing it then I would, especially since you're running a 4090.i finally got this power supply today and noticed that the 8pin connecters has a joint 8pin connecter on the same lead you no what i mean so theres 2 8 pin leads with 4 connecters . is this safe to use on my 4090 as i use a lian li strimer for the 4090 its a 3 8 pin connecter to the 12phvwr connecter into the 4090. the reason im asking this is i always thought its better to run of a separate power cable and not 2 of the one lead//sorry if this is confusing..
this my 12pwvr lead .
