So at the moment you're paying your pension post tax anyway aren't you? So your gross salary and qualified earnings are the same figure?
So Im not sure if that helps you to know what they would do under salary sacrifice unless you have specifically asked?
Minimum that has to be contributed by your employer
As part of the overall percentage, the government has also set a minimum percentage that has to be contributed by your employer.
These minimum percentages do not apply to all of your salary. They apply to what you earn over a minimum amount (£6,240 in the 2023-2024 tax year) up to a maximum limit (£50,270 in the 2023-2024 tax year). This is sometimes called ‘qualifying earnings’.
I've found the figure £6240 as the threshold for mandatory contribution in a workplace pension. So your company are contributing the bare minimum they can do to comply with the government rules.
That's harsh.
Any good websites for seeing what you should have on your pot by age. I'm sure I found one one but can't find it again. It had percentages on it as well so you could by age see where you were.
I find Aviva's calculator pretty decent, as it shows annuity, drawdown and if you took the whole pot at maturity in a simple interface: https://www.direct.aviva.co.uk/myfuture/RetirementPlanner/AboutYou#assumptionsAny good websites for seeing what you should have on your pot by age. I'm sure I found one one but can't find it again. It had percentages on it as well so you could by age see where you were.
My company do a similar thing, they put it in a target retirement dated fund, which you cannot view performance before you invested into it - which I've been in for 3 years, its done "ok" gaining 5.5% each of those 3 years but I took half of it and moved it into a US Equity fund which has been performing circa 20% for the past few years, I'm tempted to move it all out of the dated fund. makes me a little annoyed that I have potentially missed out on circa 15% a year for the past 3 years!I had a look at mine today, still disappointing how little is in there and how much it is projected to be when I retire! Had a sniff around the funds (it’s managed by legal and general) there seem to be about 28 different funds it could be in but the whole lot has been in a new fund called ‘growth’ for the last which is only a year old so hard to compare over the longer term with the other funds, it is equity based and mostly US which seems sensible although I am tempted to diversify it and split between two similarly performing pots to hopefully a get a better long term average! The web portal seems intended to make it deliberately difficult to see how your money has been performing!
Is "default lifestyle" in reference to the Vanguard Lifestrategy tracker or something different? I significantly reduced funds in LS and moved this over to SP500 (VUAG). Pensions are split between VWRP and VDWXEIA; I appreciate the significant overlap between the 2 but hedging my bets the UK will continue to perform poorly over the next decade or so.My funds have averaged over 10 per cent per annum over the last 10 years. I track their performance every month and I only invest in global equity trackers. The default lifestyle fund is basically a tax on stupid people.
Have a look at my post history in this thread if you want to consolidate into a low fee global tracker structure based on Vanguard funds.Wish we could have a poll on "what vanguard funds are you in? "
I'm switching to vanguard this month. I have 5-6 individual pots in whatever they have always been in.
Time to start consolidating.
A bit harsh.
A tax on people who aren't saavy in finance.
It is hard. I consider myself way above average and it's quite confusing.
(the average bar is low)
They'll 'lifestyle' you into more and more bonds as you get older and you'll miss out on a lot of growth IMO.Mines just in a vanguard target retirement thing. I don't know enough to do anything else with it.
