Just because it’s a 5kw inverter that doesn’t mean it will do via via the battery and many are only 3.5kw on the battery and only 5kw via solar or a mix of solar and battery.
That's decent, probably worth sticking with that if you're happy with it.currently on eon with their SEG @ 16.5p/kwh and eon's EV eco 7 is 8p/kwh between 0000-0700
i think the equivalent is octopus go but they reduce the SEG payments to 8p/kwh so not really worth it
yeah, i'm pretty sure i'll stick with eon as i just want a "set and forget" system and not one that i have to continually manipulate to get the best £££That's decent, probably worth sticking with that if you're happy with it.
Do you have shading issues?Evening,
Work has the Octopus EV Salary Sacrifice scheme which has peaked my interest. Low and behold that has sent me spiralling into the world of solar and battery storage.
I live in a new build (4 years old) and in the builder infinite wisdom they decided against running any significant power supply into the garage, only extended the downstair main ring. Power comes into the builder smack bang in the centre and getting to the garage is going to be a royal pain in the rear.
So my thought process is.. if I'm going to do it, let's really do it.
I reached out to Infinity Energy and they came back with a proposal, this is what they suggested.
12 x Jinko 440W mono-crystalline solar panels
Renusol Variosole On-roof mounting system (10-Year Warranty)
1 x SolarEdge 5kW solar inverter
12 x SolarEdge S500B Power Optimisers
1 x Tesla Powerwall battery 13.5 kWh
If on-roof, 1 x Bird Protection
MID-approved generation meter
All DC and AC isolators, cabling, trunking, etc.
Roofing labour
Electrical labour
Scaffolding and access equipment
MCS Certificate (Solar aspect only)
5-year insured workmanship warranty (Solar aspect only)
Grid connection notification
Total fee for Solar Panel System: £6,667.89 inc. 0% VAT
Total fee for Battery Storage: £7,368.00 inc. 0% VAT
Our total fee, including all of the above, is: £14,035.89 inc. 0% VAT
What do people think? It's quite the total figure.
They certainly know how to charge for a Tesla Powerwall - you can buy 30kWh of storage for £6000 or 15.5kWh for £2500, admittedly the Powerwall is a lot more refined, has a built in inverter and gives whole house backup, but is it really worth that much, I don't think so.
It's expensive but you've basically picked the highest end equipment for a consumer installation which has prompted some questions:
Is this one roof?
Do you actually need solar edge - e.g. is there shading no your roof?
The Powerwall element is overpriced IMO. The equipment cost is only £5800 and there just isn't £1,500 of labour or sundry items to install it unless it is some ridiculously complex install, particularly when they will already have an electrician on site doing the solar.
Edit: as for the EV charger, where is your meter box? They can connect the charger there if needed.
As aboveDo you have shading issues?
These guys are the same people who installed mine. You won't be disappointed with the workmanship but they arent the cheapest around.
It’s a mix of south east and south west, no shade other than natural shade from the transition of the sun over the property.
Meter and the consumer unit are at the same location, under the stairs bang in the middle of the house.
