- 15 Mar 2007
The evidence on its increasing performance seems to be 1 to 3 frames per second. Do you guys activate it ?
Would love to give it a try but I don't have that option in Windows 11 for my 6950XT. I thought I read about it being enabled for RDNA 2 some while back but I must be mistaken.Anyone activate HAGS?
Ah, thx for that, must be Profile Inspector i was thinking of then, and that was like you said, just for forcing it for specific games, cheersIn Nvidia control panel you should see that it shows ReBAR is supported and enabled:
That's it. You can forced enable it for specific games if they don't have it enabled at the driver level since Nvidia whitelist the option for all games in the driver. Profile Inspector simply allows you to manually whitelist games but if they are not whitelisted by default then any performance uplift by manually doing so isn't going to be of any benefit anyway. NV tend to update the whitelist as games get fully tested and confirmed to make use of ReBAR so just leave it be.
None of the games I play have these issuesI leave it off as it causes instability in some games making them crash, also stutter can be introduced even worse with it enabled.
I am happy for you, Hogwarts Legacy is one of them as for the most recent personally.None the games I play and these issues
This is not true. There are instances where non whitelisted games have increased performance with REBAR enabled. Modern Warfare II performance significantly improved by manually enabling it for me.That's it. You can forced enable it for specific games if they don't have it enabled at the driver level since Nvidia whitelist the option for all games in the driver. Profile Inspector simply allows you to manually whitelist games but if they are not whitelisted by default then any performance uplift by manually doing so isn't going to be of any benefit anyway. NV tend to update the whitelist as games get fully tested and confirmed to make use of ReBAR so just leave it be.
