I'll try again see if another agent offers anything better I got till 1 monthHow are you getting on with this Asus router?A router with at least 2 x 2.5Gb ports. I'm using this one with Merlin firmware for that reason so one port from the SH5 and the other to my PC motherboard which is 2.5Gb
ROG Rapture GT-AX6000 | Networking | ROG United Kingdom
Dual-Band WiFi 6 Gaming Router, Dual 2.5G WAN/LAN ports, enhanced hardware, WAN aggregation, VPN Fusion, Triple-Level Game Acceleration, free network security and Mesh WiFi Systemrog.asus.com
Do you recommend it?
Good to hear. Stock firmware or Merlin?I've had this about 18 months, it's great. Never skipped a beat.
Within reason they will install where you like. General rules and common sense apply eg. they can only officially bring it in via the front of the property, if you want it pulled under the floor boards or through the loft, they will drop the cable off and let you get on with it on the understanding that they wont deal with the re-pull if it develops a fault as they cant crawl about in your un-boarded loft or lifting your floorboards. They also can’t climb on roofs, or use ladders above a certain height.Have seen Virgin contractors rolling out cabling in my street. Asked them if it was Nexfibre, they confirmed it was but could not give me a possible service start date which I was eager to find out. I am currently on FTTC 50/10 from Zen. This Virgin offering will be the first FTTP in my area, so not a lot of choice, and would be looking at 1gigabit for upload/download service. Have a couple of questions for anyone who has Virgin Nexifbre.
My BT master socket is located in upstairs bedroom where current router is situated. I know Virgin do not use master sockets but install their own cabling/plates. During installation can one opt to have it installed upstairs ? I prefer wired connections rather than wireless, so dont want the hub downstairs as have not ethernet cabling between upstairs and downstairs.
and 2nd question, does the Virgin hub 5 offer bridge mode ?
I could be mistaken, but I don't think the Hub 5x does modem mode?All VM Hubs since the first Motorola Surfboard have supported modem mode, thats not going to change.
At one point it wasn't officially supported on the 5x, but could be enabled, subsequent firmware enabled the usual tick box/reboot approach.I could be mistaken, but I don't think the Hub 5x does modem mode?
Now there's a name I'd forgotten about!All VM Hubs since the first Motorola Surfboard have supported modem mode, thats not going to change.
Just stock mate. Works fine for what I need it to do.Good to hear. Stock firmware or Merlin?
Recent firmware update has added in modem mode.I could be mistaken, but I don't think the Hub 5x does modem mode?
The mark of a good ISP is not having to deal or interact with them post install. VM aren’t renowned for the best network or lowest latency, but honestly other than renewal negotiations, I never had to contact them and it more or less just worked as expected. Of course fibre is lower latency, symmetrical and cheaper, but I wouldn’t have an issue going back to VM for similar money.Ordered last night as cash back went to £137 for the 1gb service. Should have the hub delivered Saturday!
Can’t get 5G in my area. What are your upload speeds like and what’s your ping time.They were fine to deal with but expensive tbh. I'm using 5g now and getting up to 800mbit for £20. No stability issues so far. Couldn't pass on that deal, so much quicker.
