By default my Gigabyte motherboard would have both power limits set to unlimited. I reduced those to 253w, the max for the 14700k.
Also I added an 0.07v negative offset to the vcore.
The cores seem to boost to where they are needed and the 420mm AIO seems fine.
The power limits should be set at the CPU's maximum by default, but it seems that often does not happen.
Then again I am not typically using an all core sustained full load on the CPU for extended periods.
The max vcore on that screen would suggest that you are at defaults.
