My son's PC has the following:
3800X (PBO enabled)
MSI B550 Tomahawk (Latest BIOS)
32Gb (4×8Gb) Corsair Vengeance RGB Pro 3200Mhz (XMP 2 enabled) 2 sticks are recent warranty replacements and all confirmed working on my own rig.
Sapphire Nitro 7800XT (Currently on 23.12.1 Drivers after full safe-mode DDU, but have also tried minimal driver install) SAM is enabled in Adrenaline, custom fan curve but nothing else.
Fanxiang S880 1Tb (Pci-e 4.0) in M.2 slot 1
Sabrent Rocket 1Tb (PCI-e 3.0) in M.2 slot 2
MSI Mag A850GL (Cable extensions to Motherboard & GPU, 2x separate PCI-E , no pigtails used)
Lancool 2 Mesh RGB (plenty of airflow, fans on custom, fairly aggressive curve).
Monitor: Dell S3222DGM (1440p, 165hz, Freesync enabled, latest firmware).
Setup has been working great after an update at Xmas (New CPU, Motherboard, PSU & GPU), but the 24.xx Adrenaline drivers caused a drastic reduction in FPS across all the games he plays (Fortnite, Rocket League, Forza 5), even when stopping settings down to bare minimum.
The games are stuttering around 30-90fps, regardless of whatever troubleshooting I try, even after Safe Mode DDU & rolling back drivers to the 23.12.1 version
I'm at the limit of my knowledge in terms of getting his system back to the smooth, high FPS rig it was in January and would be grateful for any helpful input.
3800X (PBO enabled)
