- 29 Aug 2010
- Cornwall
So I just built a new PC, installed Windows and it all seemed fine.
Was just doing some Windows updates and installing some drivers as you do, it needed to restart, so I did. But from that point on it wouldn't boot into Windows. All the motherboard LEDs go out as I believe they should. If the screen comes up because Windows has failed to boot enough times, that menu works fine. I can boot into safe mode, but it won't boot into Windows.
I used a Restore point and then it worked again, for a little bit and then the same thing happened.
Then I got it to do a self re-install of Windows using the installed version. That worked, so I then downloaded the Win10 media creation tool and used that to "upgrade" windows. It then seemed to work again. I was just installing and uninstalling a few things and it needed to reboot and from then it won't boot again.
SFC /scannow says it fixed some corrupt files but it doesn't change anything.
Same symptoms each time, the "lock" LEDs on the keyboard flicker then either all stay on or all go off. Then after a few more seconds the monitors go to standby.
Anyone got any ideas?
