- 2 Feb 2020
- UK
Hello,
I got a flat rear on a Ford Focus, it's a Continental 205/60/R16.
The other rear tyre seems in decent condition, is it safe enough for me to just replace the flat these days? I assume it's recommended to get the exact same manufacture/spec - but I remember previously being told you need to replace in pairs? Can I get away with just doing the one?
Also, do I need to ask for alignment or anything when I get it replaced? I'm hoping they would check for any wheel damage as standard as I had to drive on it flat for a bit to get off the road.
Continental EcoContact 6 (205/60 R16 92V) looks like £154 fitted as an exact match if I can just do the one.
Thanks!
Thanks!
