Wait rheres Ray traced minecraft?
Oh noes - did you get your stuffs back though? Yar, that farm is in spawn chunks, so is always loaded, which is why the bits despawned.I got creeper bombed at the "spawn" the iorn farm seems OK but in not sure if I broke the bone one?
.sorry happy to help fix but by the time I got back everything had despawned and I really don't get what the mechanism does
Essentially, that is correct. There are *some* exceptions, spawn chunks are always loaded whilst the server is on regardless of playercount, plus there are ways of chunk-loading in the vanilla game, but that's a more advanced/technical type of play.This seems like the best thread to ask in:
I'm running my own Minecraft server on a little home lab machine. Have I assumed right that leaving it running has no advantages if my player isn't connected? I.e., if I set up farms or whatever, they won't be running because me not being connected means those chunks aren't loaded, and so aren't simulated?
Hi, can anyone connect? Do you need to whitelist usernames for connections?Exciting news - I'm changing the host of TheMustardSeed, so the connection is now different:
themustardseed.duckdns.org
Any problems connecting, also give me a shout, either on here or on the discord. Both worlds will run for a few more weeks, until the renewal runs out on .mcserver.ws I won't be transferring any progress on .mcserver.ws to duckdns.org so fair warning to only connect with the new deets
Yes, anyone can join, whitelist is on though. I've added you, so feel free to hop on!Hi, can anyone connect? Do you need to whitelist usernames for connections?
Thanks. Just logged in and had a quick look around. I'll be back on tomorrowYes, anyone can join, whitelist is on though. I've added you, so feel free to hop on!
No problemo - catch you in game.Thanks. Just logged in and had a quick look around. I'll be back on tomorrow![]()
I Thought you were Tefal12, granted this was almost 14 years ago nowHey is this still running? I'm feeling a bit of a Minecraft itch latley. Tefal21 was my minecraft name, don't know if you copied the link tart whitelist too.
Is industrial craft a thing these days? I miss lava pipes![]()
i have no idea what any of this is >.<
whats a totem? or elytra? i found some emeralds at the top of the mountain.
there's tnt duping/ i remember we had to farm it in the huge spawner and like you say nuke a desert or two.
i have some ideas for large scale projects, give m an hour to type up the vauge outline + fix the typos. in the meantime, i dont have my hdd from back then but i had a few screenshots from back then that steam has saved. of our nether portal room, from the dwarf build, this was essentially just the front porch lol
i cant remmber how we planned out the dome, i think it may have been pen and paper.
with the new hights we could build vastly tall underground builds. or use the extra skybox hight to make great new structures. ive identified some sites that could be good for multiple projects. its a bit weird this is the fuirst time ive really used my laptop for typing in a few years lol instead of the phone.
the good old days, never did finish the big pit that was to be the entrance hall/statue hall of the dwarf build, steam fortunately still has the screen shots i took of sylvet's skin to model for his statue in there, it was going to take so many chests of lapiz lazu to build. but it does give me one idea to take the dome idea of the nether portal room, expand it and turn it into a larger lighter pantheon style structure , with a syl statue, and around the edges a large doubble helix stair case, and multiple floors mezzanine of barrel storage with signs of every single player obtainable item in the game in honour of his tireless work of sorting every chest in every major build on the server.
