Why would it be drawing from the grid when solar is over the demand?
Is that not reading as negative 110w grid power, and as 110w on the feed in to the grid?
It’s import, look at the trials.Is that not reading as negative 110w grid power, and as 110w on the feed in to the grid?
. 170w house load, 60w from the inveter so the other 110 must be grid import.It’s import, look at the trials.
Also add up the numbers. 170w house load, 60w from the inveter so the other 110 must be grid import.
Ah the beauty of Solax!...
As said its a snap short of the precise time at 5 minute intervals.
You will see if you drill down naff all actual usage but it can happen.
You can switch to live data if you want but it reverts to the 5 minute slices.
its not export its 100% importing at that pointIt's export, look top left Grid Power -110.00W. Grid Feed-in, means exporting to the grid, grid feed-in should be negative when importing, as Journey says, its a poor and confusing graphic. It should be labelled Grid and positive when importing, and negative when exporting.
@Mercenary Keyboard Warrior I agree he is right, my my point is as explained in later posts the display doesn't follow normal conventions, and thus is confusing to anybody that doesn't know the way that particular app displays its information.
You've quoted normal conventions and no standard.I didn't see your ninja edit, like most things there's no standard (that I'm aware of), and as I said people in the know, thus Journey and myself both misread it. Anybody who's not more clued up won't know the difference they'll just get use to the way it displays the information.
I did study what was there, and drew my own conclusions, based on my own knowledge.Seeing as there is no standard you should probably study whats there and not assume. You know what they say about assumptions
Don't need it down south judging by the negative pricing. Generation exceeded demand grid wide most of the day looking at it.The grid carbon intensity in my area right now is 8g CO2/kWh and it’s currently 40.5% wind, 30.5% nuclear and 27% solar with 2% gas and biomas.
Absolutely nuts, I’ve never seen it so low.
I expect wind turbines are being curtailed right now because we don’t have the pylons to send it down south yet.
