Very slow internet through Ubiquiti Cloudkey Gen 2
25 Oct 2005
Hi,
I've been running my internet through a Vodafone router/modem, into a Cloudkey then out to Ubiquiti Wireless AP for some time now, relatively successfully.
Recently I had some electrical work done and so have been using the vodafone wifi as I had that on battery back up. For several weeks the power was off & on, and as we were having decorating done too the AP were removed from the ceiling as well.
Now that the work is all completed and in preparation for us getting full fibre in a couple of weeks, I wanted to move everything back to using the Ubiquiti wireless and that's where I'm having problems
Through Vodafone WiFi I'll get around 70Mbps, through Ubiquiti I'll get 4-10Mbps, and I have no idea why. Also things that are connected to the network switch (eg I have a fire alarm hub) or connected to the WiFi (like my Ring alarm) and sometimes one of the wireless AP keep on reporting network issues. Basically, the it's all a bit pants - slow speed and patchy network.
I thought it may be a problem with the LongRange AP as our decorators left it hanging off the cat cable, but I disconnected it and no joy. I also removed everything from the network switch except the vodafone modem/router, cloudkey and one wireless AP, but still have the same issue.
Any advice on how to proceed / trouble shoot?
OP
25 Oct 2005
It goes into the vodafone router, which is hooked up to a netgear network switch along with the cloudkey, 2x Wireless AP in the house and 1 in the garage; a Philips Hue Bridge and a fire alarm hub.
So maybe it is the output of the vodefone router or the network switch?
19 Nov 2021
Portsmouth
First thing I'd check is the speed of a wired device plugged into the switch. Get the radios out of the equation completely.
You say things connected to the switch are giving internet connection issues - I would start with the wiring between the router and the switch, or maybe plug the router into a different port in the switch in case that port is failing.
OP
25 Oct 2005
Well it's a bit weird.
I unplugged all the Ubiquiti stuff and put my PC into the network switch directly wired in and got normal speeds of 70Mbps. Then I plugged the cloudkey back in and on of the AP in the garage; low and behold that gave me normal speeds too. Then I plugged in one of the APs inside the house and that gave normal speeds. Got distracted for a while, so plugged in the Long Range AP just now and speeds plummeted back to 4Mbps. Unplugged that AP and speeds are still low. Going to try replicating that and try a different cable on the LR AP.
19 Nov 2021
Portsmouth
So wait, with the LR AP plugged into the switch, your wired connections dropped to 4mbps?
19 Oct 2010
Could be for some reason your client is connecting to an ap furthest away with a weak signal.
From within UniFi confirm the ap you’re connected to.
29 Dec 2002
Forgive me, while it should work etc. etc. the AP and AP-LR went EoL March 1st 2021 and they shipped with 10/100mbit ports and were 2.4Ghz N300.... If you're getting fibre, perhaps consider something slightly more modern? Whatever your ISP gives you will likely be significantly better.
OP
25 Oct 2005
I think this is part of it; combined with the LR being funky. I might reset it and see what that does.
Sounds like some of the parameters of the LR AP may be broken and need reviewing
Feels that way; I’ll see if resetting it helps.
I was using AP generically. I have the U6 Lite and U6 LR so should be good.
I will try what comes with the ISP anyway to see what that’s like. I wanted to get a Dream Machine Pro but can’t justify the expense. Once I’ve got the full fibre I’ll have a rethink.
19 Nov 2021
Portsmouth
IMHO look at something like the UXG lite or the UXG Max rather than the DMP unless you need the extra applications. You already have the console (CK-Pro)... (or even the Cloud Gateway Ultra and ditch the cloud key if you only want Network - that price point is compelling)
OP
25 Oct 2005
To add to this; it does look like it was using an AP that was downstairs or the one in the garage instead of the LR which is in the upstairs hallway and really what I was hoping would cover the house; then the one downstairs for the kitchen / back garden and garage for the rest of the garden but also the Ring cameras at the front.
I’m a bit disappointed in the range of the U6 Lites, but maybe I’m expecting too much? Need to see if I can get them working better .
19 Nov 2021
Portsmouth
Ok because I am dumb and never understand network stuff; would I need a modem on top of this?
Depends how your fibre is presented to be honest. If it's a plain old ethernet connection then you don't. I don't know enough about FTTH implementations in this country to comment more, really. I'm with hyperoptic, it's active ethernet with an RJ45 1GB port on the end of it, router plugs straight in with DHCP set up. No idea how the other operators work - sorry.
OP
25 Oct 2005
Hopefully getting fitted next Friday so we’ll see what I get. They already cancelled once as they have to install via an overhead cable and need to go over live power cables, which apparently takes multiple teams of people to do safely.
