Deleted User 298457
Deleted User 298457
I'm not sure it is possible to talk sense to someone who wanted a "sporty engaging drive" who has ended up with a low spec 320D manual as their goal
Because stop-start traffic with adaptive cruise control works seamlessly with an automatic, and the ZF8 speed is amazing.I don’t get why people keep saying this. If I’m putting it in manual mode why not just get a manual? I’ve point out a few times that I enjoy changing gear manually.
Nothing to do with speed or sportiness
Looking for advice on warranty.
Had quotes for my M2...
Comprehensive:
£0 excess £1309
£100 excess £995
£250 excess £793
Named component:
£0 - £1034
£100 - £827
£250 - £666
All above exclude roadside assistance, as I have AA cover via bank account.
There's also driveline, however I am not tempted as the claim limit is £5000, which I don't think would cover a 'major failure' of DCT gearbox or engine
I am tempted by named with £100 excess, however are there any major components that I would be missing out on that I should go for comprehensive for? I know all the screen, interior bits etc wouldn't be covered but my major concern is engine, gearbox, and diff.
Don’t care about speed. It’s about ease.
As I’ve pointed out a few times the kick down is jerky, clunky and annoying. Only the PDK is silky smooth in this instance.
I've never had my ZF8 try and change up a gear as I approach a roundabout for example!
This is the way.Comprehensive:
£0 excess £1309
£100 excess £995
£250 excess £793
Named component:
£0 - £1034
£100 - £827
£250 - £666
Did you not say you had an F31 with the ZF8? Knocking to the left doesn't do this. It downcogs by 1 gear and engages the sport mode for the gearbox, and cuts out stop start. It's still much easier than changing gear in a manual.
I recently drove a new Macan GTS PDK and the PDK is good, but in normal driving it's certainly no better than the ZF8.
Now I will grant you the DCT in my M4 Competition was far from ideal for daily driving, it's ok, but the ZF8 is far better in traffic etc.
I'd be very interested to sit next to you and observe these things you mention, I've never had my ZF8 try and change up a gear as I approach a roundabout for example!
A manual is perfect in a Caterham, simple sports car or a **** box, but for daily driving I don't know why you wouldn't get a ZF auto.
Not all auto boxes are good though - the one VAG uses in its Golfs, etc. is a total POS.
Because you can't put a manual into auto mode when you're in traffic or driving around town and because manuals are much harder to buy?![]()
  Nor do I drive around towns.If you don't care about speed you won't need kickdown. It'll just smoothly and seamlessly accelerate back to whatever speed you want. There is simply nothing to do with your gearbox on a Motorway or a dual carriageway if you don't care about speed and care about ease. Caring about ease of use rather than speed is basically the entire point the automatic gearbox existed in the first place.
I respect that everyones experiences are different (But it's an interesting argument anyway!) but I just can't relate to this problem you've had on dual carriageways and Motorways. I never think about what gear I am in on those roads - if I want to accelerate I just do so, the gearbox sorts everything out quickly and smoothly. You often don't even notice it shift down if it only goes down one gear. Obviously you'll notice if you use kickdown but if you're using that you obviously want maximum performance so doesn't really matter.
I can think of no better combination than a decent engine and this gearbox for effortless motorway driving with a petrol or diesel engine car. It just works. It is much smoother than dual clutch gearboxes, so I am surprised you've found one of those to be smoother. I don't think I've ever heard of a case of a dual clutch being smoother than a traditional torque convertor.
On the motorway the 8th zf gear probably has a lower ratio, than manual 6th, so may have some additional motorway fuel economy/lower emissions.
cursory google 5th manual like 6th on zf, 6th man 0.846, zf 8th 0.64 ... but maybe there is a final drive ratio to plugin too ; I'm doubting fuel is 5% less at 70mph though, but if it were ....
[being able to manually drop multiple gears directly, too what is required, at roundabout, is another point)
I'm not sure it is possible to talk sense to someone who wanted a "sporty engaging drive" who has ended up with a low spec 320D manual as their goal![]()
I have paperwork to prove I am stupid akkksshually. It was just a synonym phrase for wanting a manual.I know you're not stupid enough to make up the fact I wanted a "sporty engaging drive".
Hard to buy doesn't mean impossible. Why is that even a valid reason to not get one?
"Don't buy that car on Auto trader because it's only one of six, when there are over 100 automatics you could have instead" - c'mon dude, that makes no sense.
But it does kickdown, in my experience.
The auto is programmed to be in the highest possible gear for a speed. So if I'm at 35 in 7th at 1000 RPM it's always going to change down to accelerate (just an example - I don't know which speed corresponds to which gear)
The bottom line is that I just enjoy changing gear, even in traffic. I get driving enjoyment from moving the gearstick from 2 to 3. Car/speed irrelevant.
Great, but I WANT a manual.
My 428i runs at 1,900rpm at 70mph in 8th.On the motorway the 8th zf gear probably has a lower ratio, than manual 6th, so may have some additional motorway fuel economy/lower emissions.
Yep, I think you’re wasting your time Fox (though I agree with you).Can we talk about something else now please?
is the emissions obligation of the (virtuous) mild hybrid not part of the reason for manual's demise;Unfortunately nobody else who buys a 3 Series does, which is why 2020 was the last year it really existed.
as commented before, not a potential reliability issue I'd want as a second hand owner ,
only heard another r4 programme today about car insurance hikes of 50% over last year because cars are increasingly complex to fix, I have only ever priced up manuals (not mhev/zfs)
Not a major driver but could be a consideration. Autos just got good and could afford more gears.is the emissions obligation of the (virtuous) mild hybrid not part of the reason for manual's demise;
I didn’t say that. I think the automatic is better in general.Out of interest, why do you agree that Fox thinks the automatic is better for me?
