Your want for one will decrease rapidly the moment you drive one![]()
I think that's probably true of most classic vehicles tbh
Buy a £50k TVR and find another £50k for repairs/upkeep.
TVR running costs aren't generally especially high relative to the performance. Obviously they cost more to run than a Ford Focus, but generally speaking.
Probably cost less than most 'modern' cars thoughespecially an older BMW or Mercedes. Getting a Porsche serviced by an OPC isn't exactly cheap.
My best mate bought a Cerbera Speed 6 last year. The first thing it presented him with was an engine rebuild quote of £13,000. In the end he bought a used engine for around £4,000 but the bill overall was still enough to give your average motorist an aneurysm.TVR running costs aren't generally especially high relative to the performance. Obviously they cost more to run than a Ford Focus, but generally speaking;
Generally speaking, the older models (Chimarea/Griffith and earlier) largely used off the shelf parts. Availability is an isuse for some parts, but in the main, the parts availability, especially consumables, is pretty good and/or there are alternative solutions available. The problem parts are things like wing mirrors and lights, which were taken from common cars of the time (Citroen BX, Ford Fiesta etc) but are now hard to track down.
The more recent models (Cerbera onwards) are more expensive to run as the parts are more bespoke. Things like brakes are more expensive, but they're just off the shelf AP Racing parts. Engine servicing and maintenance costs jump up compared to the RV8 models and you'll need to use specialists, but I can't imagine they're any more expensive than a Porsche for example.
Reliability stems from questionable cost cutting measures and failures when they were new - such as the infamous issues with the Speed6 engines, which stems from TVR making changes to the engine design to save manufacturing costs iirc and storing unprotected chasiss outside, so they were already rusty before even being used. Now that they're 20+ years old, specialists have figured out how to rectify these issues and most owners have had engine rebuilds, chassis refurbs etc by now. Top Gear etc probably didn't help matters either!
The chassis situation is a double edged sword, as yes, it may require rust treatment/welding/refurb, but it's a lot easer to do this with a body on chassis, than a monocoque design. So it's swings and roundabouts really and shouldn't really need doing on a regular basis as they're generally weekend/summer cares now.
Most will be better now than they were new from a reliability standpoint and a lot probably bettter cosmetically too.
Looks nice though.
It was a cracked block in his case, but the specialist said it was a real mess overall even without that.Buying a TVR is like buying an RX7/8 but at a more expensive entry point.
Buy it knowing you have to rebuild the engine then all is okay. From what I have read the speed 6 is quite a reliable engine once it has had the right modifications done to it.
On the Billet Rotary website, guide price for a 20B short block is around £28k. So by the time it is landed and fitted. You may do it for £50kI'd love an NA 20B or 26B to go in my RX-7. Don't know if you can even manage that for £50k these days!
