- 12 Feb 2014
- Somewhere Only We Know
Hi, I just need a little bit of help with fitting a DDC pump to an FLT 80, the instructions from EK a pretty much useless, with only 2 pictures and about 4 line of text, ive pressurized the system umpteen times and always lost air, reffitted the pump and still loosing air, what I cant work out although you are meant to use the DDC O ring supplied, are you meant to leave the D5 O ring in situ too ? the instructions just say to remove the D5 bracket and fit the DDC O ring, they dont say anything about the other O ring which fits into the groove on the res.
