Yes.Can you have the 15p fixed export on agile???
Appreciate this is a home solar thread, but can anyone point me in the direction of a suitable unit for my Dad's allotment?
He has a 10'x7' shed with a south facing roof. Panels could be permanently mounted, to charge something like a Jackery unit.
Main use would be LED lighting & music (he has a gas stove for hot water) - I appreciate he's not going to be running 2000W tools off of it, but will probably want a Makita 18V battery charger for his mower/strimmer.
Budget is up to £750 (bonus points if we can keep it under £500).
Found this the other day.Can you have the 15p fixed export on agile???
Will see about switching to agile then…some half hour slots are minus pricesFound this the other day.
This for me too. I'd go nuts thinking and checking figures every minute of the day... Can't stop my brain from wanting to squeeze every last bit out. Best to avoid it for me I think!I can't be doing with it personally, but he's retired so guess has the time to manage it.
I think I may have to look at Agile for next winter, I could also automate it.that said agile has been far cheaper than the other options for me over winter and I automate the charging so not really hassle
Heres mine over 3 months, figures exclude export so flux could get bumped up the list a bit if you export lots in the peak window. Discrepancy between my price and the agile price is the new slightly higher standing charge on agile today.I think I may have to look at Agile for next winter, I could also automate it.
Octopus watch. It may or may not be one of the paid features not sure.Which app is that for comparisons?
but if I was on Agile then charging and exporting would be different, so very difficult to compare
During winter though assuming we get saving sessions again exporting in the flux peak window will be a loser anyway. Flux is quite poor in winter in my opinion.It's not a subscription feature as I have it on mine, mines says:
You: £446
Agile: £268
Standard: £702
But it doesn't take into account exports, which is annoying.
I'll have to see what I've exported, but if I was on Agile then charging and exporting would be different, so very difficult to compare
Yes it makes sense. Personally I dont min max it for 2 or 3p though, only when its very cheap I will force it.I'd probably still charge when cost effective to do so, if there's a nice cheap period, or even negative coming up it would make sense to force discharge, then charge when cheap, but it would need automating.
It would be nice to see them introduce something that helps flux users in that regard. Seems wrong that the saving sessions handicap their flagship solar and battery tariff.Saving sessions was one of the issues I had, I could only export for peak between 16:00 - 16:30 and 18:30 to 19:00 at 8kW although i think we did have one session after 18:30.so lost a bit there.
That said, I often didn't have much battery capacity left to export much more due to lack of sunshine .
I wouldn't bother for a few pence, not sure what I'd use as a cutoff point though.
