- 29 Sep 2010
- Cumbria
I've built a few shops for people using a template I had hacked about from an original. I have had to build a new template based on bootstrap to upgrade due to php deprecation. I have pretty much done what I need to do but I cannot for the life of me get the woocommerce product search results to display the products, its just displays the term but no link...
My other sites display everything as if you was just clicking on a category, with he product items coming with view item button.
If I search 'Mix', even with a woocommerce search plug in the out put is below.
It should look like this ...
There are two products with the term in with one of each of the above in title and description.
This is all it shows. Just plain text. Anyone have an idea if where I should be looking to sort this. I got it to work previously but at was at least 5 years ago since I needed to do it and I can't find out where or how I did it ! I deleted the search template to test and the same output without one.
Thorough research online has been useless as all the results suggest get a plugin for this that and the other, and no useful tutorials, which I used years ago to figure this out before.
