- 28 Dec 2017
- Beds
You can put a smart light switch unit in parallel with the switched live that triggers the extractor. Basically a second light switch that just feeds the extractor sense wire.
Ah nice, will look into it, thanks.You can put a smart light switch unit in parallel with the switched live that triggers the extractor. Basically a second light switch that just feeds the extractor sense wire.
It was a 20mm SDS jobbyCan you say "bored a hole" if its like an 8mm drill bit?![]()
You put a tube in a fluorescent holder? Aren't the LED battens like dirt cheap? I think I grabbed a LAP one for my attic that was 3ft long for <£40.Rushed to Screwfix 10 minutes before closing to get an LED tube light to replace a fluorescent.
Wired the ballast out and wired the neutral/switched live directly to the tube fitting.
Turned it on. It popped, loud. Crapped my pants.
Try again tomorrow I guess![]()
Going from one to two strips as garage becomes workshop. For now I got an LED tube for a tenner, I'll choose battens when we have a ceiling haha.You put a tube in a fluorescent holder? Aren't the LED battens like dirt cheap? I think I grabbed a LAP one for my attic that was 3ft long for <£40.
I get 5% discount, I use them the few times it works out cheaper than Screwfix but it's not often. The industrial estate my local place are on also has an annoying ring road with 5000000 speed bumps.On the few times I've used Toolstation, I've always been told my order is ready then arrived to find something out of stock. Won't go there unless I'm forced TBH.
Love a Titan wet & dry.Floor can almost go fully down though which will be a relief...
They're great but wish they did a stair proof versionLove a Titan wet & dry.
They're so cheap, just buy another to clean up the mess. Baller.They're great but wish they did a stair proof version
