3090 FE thermal pad replacement success!
I replaced all the pads and paste on my 3090 when it was new it used to hit 100c easy and throttle so i bit the bullet and bought some gelid pads and decent paste, at the time i was cacking it doing it but it dropped temps by nearly 20c overall and ran much better
Are original pads wrong sized? Or dont have full coverage?
It's a known issue that they're just poor pads which don't really function that well to start with and degrade over time. Mine were like very soft marshmallow when I went to take them off.
What paste did you use out of curiosity?
It wasn't as my 3600X bottlenecked big time so i also had to buy a 5800x3D :rolleyes: but then it was unleashed to be fair the 3090 was probably bottlenecked too at the time
Aye, I feel my 3090 is probably a bit bottlenecked by my 5600. At any rate, I'm not in a position to upgrade my CPU or graphics card at the moment, so I will carry on like this for a while. The 3090 is still coping really well with everything I'm throwing at it.
After seeing some outrageous temps on my 3090 FE, not to mention the jet engine-like noises it was making as a result (loud enough to be heard from a different room with the door closed), I decided I needed to do something about it. Did a bit of reading and was astonished to find some of these premium flagship cards have shipped with garbage thermal pads. So, with some trepidation, I took it apart and replaced them - very carefully. And it seems to have worked.
GPU temp: 74°C --> 71°C.
GPU memory junction temp: 110°C (!) --> 82°C.
GPU hot spot temp: 93°C --> 84°C.
Hey there, sorry for digging up such an old thread! I was wondering if you'd be able to offer some quick advice. As you used 1.5mm and 2.0mm how many sheets of each did you need for one GPU. I have multiple used 3090 FE I need to re-pad for an AI server.
I know it sounds stupid talking about being wasteful with money on thermal pads in reference to a threadripper multi GPU system but considering this is going to be quite a lot of thermal pad I need to order I'm a bit unsure exactly how many of each thickness, and which template needs to be cut out of the 2.0 and which out of the 1.5. The following cutting template by @CryptoAtHome only uses 1.5mm pads for everything. Also I see that gelid extremes are being sold as 80x40 and not 85x45 as the template is based on?
the GPUs are in pairs so if are you able to advise on a basis of 2x3090 FE that would be so helpful. Thank you in advance
