Any tips for grinding /filling ceramic tile?
12 Apr 2007
Thanks.. Those drill bits look perfect.. It's only a small job so they don't nessesarily need to last.
Think the bits might be better than a file as will be easier and less force on the tile if it's not stuck down very strongly
Just use a multi tool bit for grout/tile. If it's ceramic you'll be fine. I did the same for porcelain and took a while but worked.
