- 19 Jan 2007
- Up a Tree
Hello everyone, anyone.
I need your help.
I just completed my new AM5 build, everything was correctly installed, by the book.
I came to switch on the computer and got a black screen and no signal message on my monitor.
All the fans were running, on power supply, CPU, graphics card and chassis and everything lit up. I then tried the onboard graphics card, I have a 7800x3d CPU and still got a black screen
Then I tried different cables to the monitor etc, still no signal.
I then disassembled everything and ran it outside of the case, in case of a short, should have done this first.
Still no joy, tried without ram, then 1 stick, graphics card, no graphics card. Still I was getting a black screen and no signal.
Monitor is fine as I am using it to type this on my old machine.
Anyway, I again disassembled everything and removed CPU cooler and found there were several bent pins, eek.
Looks like I have damaged the pins on the motherboard. I tried to straighten the pins with a pin and a magnifying glass, but had no luck.
Motherboard is the ASUS B650E-I Gaming WIFI, with latest bios.
Would the PC still boot with damaged pins?
Can I RMA the motherboard, or is it tough luck?
I hope someone can help, thanks for reading.
Motherboard is B650E-I Gaming WIFI, with latest bios
I need your help.
