- 5 May 2004
- Northern Ireland
I'm seeking advice on the cause of dampness and how best to fix it.
The house is a 1970s bungalow, with a cavity wall around the exterior garage wall, and the garage space has been converted by the previous owner.
As can be seen from the photographs, two or three bricks above a slate-covered ditch show visible dampness, and then the interior wall is moist. A plastic membrane sits under the slate followed by earth/clay in which a plastic drainage pipe from the downspout sits.
Given there has been torrential rain in Northern Ireland, particularly all winter, has the ground under the slate got so wet that it crept up the wall, filled the cavity and eventually seeped through the plaster?
Is the solution to dig up the pipe, lower it below the bricks and recover it?
What's the best method of drying the interior wall?
Thanks in advance.
Thanks in advance.
- or a dehumidifier and fan will sort that out. But no point until you've found the source of the damp.
I haven't a clue why that bit isn't pebble-dashed. Around the front porch is the same.
