I'm guessing they've got some secret sauce in this regard if rumour is true. Either that or it's 4 foot long![]()
Or just fake news
Personally, I'd love to see an Nvidia GPU generation that made a real push to get the power consumption, heat, noise and size back under control (including at the top end), even if it meant slightly lower performance gains. The 900 series did something similar and sold like hotcakes.
Yeah me too. This 4080s runs cooler than the 3080 I had.To me that's what the 4000 series did. I get better than 3080 Ti performance on my undervolted profile that I routinely see under 100w playing Baldurs Gate 3 maxed out locked at 60fps.
Even playing Horizon Forbiden West I was seeing around 140w on said profile. It's awesome and you hardly hear the fans as result
I then have other profile that need 40w or so more for additional performance, but these days hardly use it.
That's because the card is too much for those games and fps. Once you let it go at its full power, the consumption will rise.
You're on 4090?Nope. Not the case with HFW. All that happens is you get less fps. But we are talking about a single digit here.
As an example. One of my profiles was using 180w roughly on HFW and was getting more fps than stock.
In the case of BG3, obviously capping fps to 60 is the main reason.
I have yet to see this card use 200w on one of my profiles![]()
Doesn't show on my phone4070 Ti sir. In my sig
Crazy efficient card.
Doesn't show on my phone)
That makes sense, was wondering how a 4090 uses only that much power without a significant loss in performance.
That bus is shrinking by the day. It'll be 256-bit by launch.![]()
NVIDIA RTX 5090 new rumored specs: 28GB GDDR7 and 448-bit bus - VideoCardz.com
NVIDIA GeForce RTX 5090 rumored to feature 448-bit memory bus The upcoming flagship Blackwell graphics card is said to feature a 448-bit memory bus, out of the 512 bits available on the GB202 graphics processor. This is a new rumor suggesting a different memory configuration than previously...videocardz.com
Yep, seems 55C is standard here, this one is the same.yea I have a 2 year old 4080 I've never seen go over like 55 degrees no matter what settings/oc I throw at it.
I love these oversized shrouds tbh. Obviously everyone was expecting the 4000 series to have stiffer cooling requirements, because these cards seem really overbuilt. So I'd vote for them being efficient, even if the bottom of the stack is hyper-underwhelming.
feel a little disappointed, was hopping for the full 32GB VRAM specially if there is a price increase.That bus is shrinking by the day. It'll be 256-bit by launch.![]()
If the 4080 launch taught me anything, it’s to expect the worse case scenario then double it.feel a little disappointed, was hopping for the full 32GB VRAM specially if there is a price increase.
Tilt your phone and it will
Yeah, that card would lose a lot more performance to hit hose numbers obviously![]()
