Days gone past I would have said yellow pages for lawnmower servicing/repairs but these days whatever is local online and look for reviews they'll come and collect in a van and drop off when doneStupid question as this is a whole new world to me, where do you take a lawnmower to get serviced? and when it comes round to this time of year when it's being used are there any kind of steps I should be taking before and after use? As I see above you've mentioned making sure to drain the fuel over winter for example.
If its that long it'd be better to just leave the box off it or you'll be emptying it every stripeThis is what I'm working with btw, first pic shows how wild it gets (last cut before this pic was back-end of Sept when it was last sunny I think) and second kind of shows the size but doesn't really show how steep it is. I know my Garden is a tip but I don't use it all, I only mow it so it's presentable.
Is E10 normal unleaded petrol as my dad's lawnmower struggles to start and tickover until warm ?My mower has the same engine, they're ok but not as powerful as the older models. Plus you need to be really careful not to use E10 fuel and even then make sure its totally drained if not using it for more than a month or 2 or you'll have to take the carb apart and clean it all.
Yeah E10 is the standard stuff, you want premium which is E5 and in some cases still has no ethanol at all even though it's labelled as up to 5%.Is E10 normal unleaded petrol as my dad's lawnmower struggles to start and tickover until warm ?
Should premium unleaded be used instead ?
Tx
Is there room on the side stairs for a sack barrow?I ended up getting the base petrol Honda Izy and took it for a spin today. Made light work of the garden, the only issue I have with it and this is very a me issue, is that there is no kind of handle on it for me to pick it up by. As I'm in a town house my rear garden is first floor height of the house so it's a pain to get it down the side stairs to put it in the Garage.
