i think they look great................ so that means you should probably steer well clear of them!.I regularly go between thinking I love these glow in the dark grilles and it's toally naff, would never have one![]()
You don't say, there wasn't a clear shot of the car in any of the sequences and if you didn't recognise the rear lights or the dash/screen you'd be hard pressed to know what it even was.As Simon had commented to me - the branding on the Mustang mach-e in the shuttle tv add was not the clearest,
but in the generation who want to wear their brands with pride - epitomized by Louis Vuitton ?
have a glowing emblem on your most expensive possession (well who would want a Barratts emblem) sounds logical.
I hadn't realised bmw have glowing badges.
funnily enough no..... and i dont like burberry either (is that still a thing or did it go out in the 90s?) anyway have derailed enough i should go to bedHave you got a fondness Gucci belts to go with all of that?![]()
If Apple had got into ev's that would have upped the branding standard.
“Yes, I’d like to store a copy of my vehicle in the cloud please.”OVer priced, unrepairable, bespoke everything, non-standard ports, form before fuction, being "brave" to remove something really useful like the brake pedal. Ah yes Apple the pinnacle of marketing, but that is about all. Oh you'd get a 'retina' windscreen though.![]()
All of those things are true, but they do just work properly.OVer priced, unrepairable, bespoke everything, non-standard ports, form before fuction, being "brave" to remove something really useful like the brake pedal. Ah yes Apple the pinnacle of marketing, but that is about all. Oh you'd get a 'retina' windscreen though.![]()
If only cars had the reliability of an Apple product![]()
Interesting that he mentions another high mileage car that has had 6 new batteries and 28 new motors. That's quite a difference in component attrition!
Yeah that's pretty smart getting the free chargingInteresting that he mentions another high mileage car that has had 6 new batteries and 28 new motors. That's quite a difference in component attrition!
He's switched on though, to see the value in that free supercharging and go all in back then took some stones.
I'm sure I've seen that car locally but I doubt he does many runs to Norwich international and it's half a dozen flights a day
The guy I know with an S had the DRL issue, and various bits that rubbed away at themselves removing paint... And autopilot horror stories come to think of it. He's still a big fan of the car though.
Those are some crazy miles. I've just been reading that he's retired, he must spend over a third of his life sat in that thing!Sadly the guy completely misspoke with reference to that car, it's 13 motors and 3 batteries - Link also done had done 1.9million KM's as of December 2023, and the early 2014 Model S motors had a fault that can't be worked around with the new design version as they don't fit.
EDIT: Motors are now much better (2022 article) 500,000Km Model 3, original battery and motor still. - Link
