Hi All,
My sister is looking to buy the below rig for her kids,
www.overclockers.co.uk
Above is the link to the pc they are looking at, a couple questions i have around it is, for the extra money is it worth upgrading the gfx card to the 16gb version for the extra £45, or is it better to just upgrade straight to the 4070 super for £175
they are looking at getting a 34" widescreen monitor so most likely gaming at 1440p or potentially 4k, so knowing which is best for those options.
games they will be playing could be all sorts, COD / RDR2 to minecraft
but they may play some higher end games
i was also questioning the ram, as this seems to be ddr4, i would put the ram up to 3600 but would OCUK upgrade to ddr5 ram if we opened a support ticket, assuming a different mobo may also be needed?
All help / advice is greatly appreciated, if there are any other pre builds within +£200 which you know of that would be better let me know!
thanks
OcUK Gaming Karambit - Intel Core i5 14600KF GeForce RTX 4060 Ti Gaming PC | OcUK
Order now online and benefit from fast delivery.
but they may play some higher end gamesi was also questioning the ram, as this seems to be ddr4, i would put the ram up to 3600 but would OCUK upgrade to ddr5 ram if we opened a support ticket, assuming a different mobo may also be needed?
thanks
