External air-cooled graphics cards
  • Thread starter Thread starter mof
  • Start date Start date
mof
mof
19 Jul 2011
Has anyone ever designed a GPU to be in an external box or stand connected with a riser cable?
They wouldn't have to worry about the dimensions or weight of the cooler since it's not fitting
in a case.
E.g. They could have a CPU type cooler on the GPU and small heat sinks for rest of the card.
Or just a much bigger traditional card like a 6 slot equivalent.
The card would always get fresh cool air and exhaust outside the main case too.
I know they've made external water cooled cards for laptaps and people could mount their air
cooled cards externally already but I was thinking of card that wasn't designed to ever go in
a case or on a motherboard so they could make a cooler how they want without the usual restrictions.
Yes external graphics cards exist, they connect to the computer with a thunderbolt connection but you will lose performance compared to a GPU that's plugged into a motherboard
Cant you buy one of the external GPU cases and then connected it to a motherboard via thunder port, Razer, asus and gigabyte all have one. You can decide what graphics card to put in there. Is this what you are suggesting?
Asus has a ROG XG mobile with a 4090 mobile.
Yeah I posted one above, there are a few different ones
Thunderbolt 4 however sucks for GPUs unfortunately and a 4090 loses 50% of its potential performance due to a lack of bandwidth on TB4. This will continue until we get Thunderbolt 5
Been around for a while in one form or another.
ASUS use a proprietary PCIE connection
Razer from 2019
To be honest all you had to do was to put "external GPU for laptop" into Google and it comes up with examples.
Quite a few on ***a competitor site***
some with AMD cards too. (OnexGPU)
@mof Try googling "JMT M.2 M Key NVMe External Graphics Card Stand Bracket 64Gbs Full Speed with PCIe 4.0 x4 Riser Cable R43SG" for another example.
It shouldn't be particularly difficult to make something up really. A few bits of wood for the box, extension from the psu for power and a decent riser card with a long enough ribbon would perform the same as any gpu plugged directly into the motherboard would. Now that the subject has been mentioned I am surprised that nobody on here has already done this as we have quite a few enthusiasts (see nutters) who think outside the box. If I remember right a couple tried making hovercrafts using Delta fans some time ago.
A decent sized enclosure wouldn't get pushed over. You then have the same problem as a computer case though, you need to get the hot air out which means fans plus more cables coming from the main pc.
I remember there was a thing for external cooling with a passive radiator that was a tower a reserator I think it was called the whole thing appears to have died a death though I once jokingly suggested you could mount it outside teh window
I had my radiators in a box on a windowsill drawing outside air in which made for stupidly low temps. :D:D:D
I think you may be thinking of the Zalman reserator?
