- 4 Aug 2007
- Wilds of suffolk
Awwww yiss, wanna go check out some planes? You'll have to LARP as an idiot that would buy my services (y)
Are your services international kidnapping?
Didn't think those had been around for 10 years or so. Once you start paying BT fees it just becomes a debt like any other.You can bounce it to another CC in many cases. Sometimes with 0pc BT fee. Although I don't see any of those at the moment.
Definitely were around in covid timesDidn't think those had been around for 10 years or so. Once you start paying BT fees it just becomes a debt like any other.
Most trackers don’t have penalties for early exits… might be worth finding one for as long as possible.Seriously considering a 2yr tracker come renewal at end of July.
Worth the risk I'm thinking rather than locking into a silly high rate for 2yrs or not much better rate 5yrs.
That's great if your mortgage is only charging you 1%... as risk free returns are around 5% at the moment.To elaborate some, in general highest interest rate wins, so if my mortgage is only charging me 1% and I can earn 5.2% (or more) myself then I should not pay more than I have to against the 1% debt, and instead use it to go into savings/investments.
I can overpay it all back in later and should be up some £'s.
The mortgage interest rate is generally fixed against the term it's in, so yes long term this plan sucks, I am going to reverse gears the minute my cheap fix ends and will wind up overpaying instead again most likely.
Most mortgages after the fixed rate period default to the banks standard variable rate which is usually absolutely awful and in reality is another one of those scams to make money out of people. If you take a two year tracker it will be well below the banks standard variable and tied to either that or the Bank of England base rate so will move up and down in line with it. Being on your banks base rate for any length of time is likely to cost you a stupid sum of money in comparison to a fixed or tracker rate.Most trackers don’t have penalties for early exits… might be worth finding one for as long as possible.
I know that when my mortgage deals runs out I default to its tracker, unless or until I remortgage with another fixed term.
Mine runs out next January and i'm thinking of doing the same currently.Seriously considering a 2yr tracker come renewal at end of July.
The issue that I and many of us have is that our mortgages are charging 4%+ and with the current rate of return for risk free returns around 5% it's a gamble as the mortgage rates may even be higher when it comes time to renew.
Anything less or around that 3% mortgage rates is the cut off for me, I would rather put my money or at least some of it towards overpayments for that guarantee return of whatever the mortgage rate is.
Personally I don't think I'll overpay mine as it's pretty much locked away. I'd rather overpay into pension due to tax relief
I know pension is obviously locked away. But you're getting 40pc relief on it. That's a lot more than 5pc on an isa or a mortgage rate
You do save the 5% every year and the 40% only once, but should be outperformed by investment growth.Personally I don't think I'll overpay mine as it's pretty much locked away. I'd rather overpay into pension due to tax relief
Pension Sharing Orders are a thingAlso helps if have a relationship breakdown.
We have our own share of the house and if I overpaid it would get messy should we break up.
Should definitely overpay into pension more if you're a higher earner, that tax relief is incredibly good. Will be unbeatable long term.
Pension is also the best tool for earning the wealth you would want to draw down later on, sure it's locked away to some degree but it's somewhere to go into more once you have short/medium term cash saved up.
- Emergency Cash for X months of living (6 months min is a good point).
- Stocks ISA for short/medium term if you need more cash than usual for something.
- Rest may as well go into Mortgage or Pension. I'm hoping to do both personally!
Its a complicated scenario and there is no right answer.
Pensions because they are locked away mean they fall outside whats taken into account if you need to claim benefits, where as ISAs and other "liquid" assets you should declare.
40% tax relief is not a 40% gain, its a 67% gain. If you were paid £100 and lose £40 to tax you end up with £60 in your hand. If you put £100 into a pension its 40/60 higher, = 67% higher for whats in the pension.
Basic tax payers is 25% extra, 20/80
