- 4 Aug 2007
- Wilds of suffolk
Saw a thing yesterday with Anker moving into the space.
Looked pretty nice actually.
I didn't think the Powerwall let you force export? Certainly when I looked a few years back your only option for that sort of thing was basically their own system where they controlled the charging and export.I've a PW2 and it's been faultless for coming up 4 years. I'd have no issue reccomending a PW.
PW3 can do 11.5kW Continuous output. That's going to be mega for gaming savings sessions![]()
Nice very similar to my system - you'll love itToday is the day they start the install, exciting. My neighbours are quite intrigued to say the least.
Well, got pigeons under my front panels (even though I have netting).
Emailed company and they are sending someone out to repair. Little buggers are noisy.
Wow, I came to post the same.
Today we found out that a bit of our anti bird stuff seems to have either come off or come loose, hard to see, but there is a couple of pigeons trying to build a nest underneath.
Going to have to contact my installer on Monday.
@Mercenary Keyboard Warrior, I’m pretty sure we used the same installer, a small section of my bird netting became dislodged during all that high wind we had earlier in the year. They were on it as soon as I reported it.
I had to send them images of the birds actually underneath the panels, before they would agree to come out.
Once captured, they were straight on to it.
I'm really embarrassed to respond to this but also I can't not thank you for your response.Probably a BMS communication issue.
Try turning it off and on to see if it clears, if not call GivEnergy or post in their Facebook group.
Edit when I say off and on I mean kill the AC to the inverter and the DC breaker on the battery so it’s completely dead, give it 30 secs and back on again.
Edit2: the dashboard should any any errors stored on the inverter page.
I don't know anything about this?I would strongly recommend battery storage, have you considered this at all?
Do you have any shading issues on your roof?
