- 7 Sep 2020
- Gods Country
Some of these posts are madness
Now there's a perfect example, original system 8 x 405w panels .Some of these posts are madness![]()
Yup, its unfortunate that people dont get or know the benefits.Now there's a perfect example, original system 8 x 405w panels .
Last year added another 4 x 400w panels.
This year upgrading the inverter and adding another 4 panels.
And those that don't know, he has an extremely low usage, but still see's the benefits of a bigger system.
Are you adding these panels to an existing string?Need more panels(4) as I have another 16kwh battery in the build stage.
My neighbour had an install done with https://www.tileenergy.uk/
With a Tesla power wall thing it was £22k!![]()
This. It's still the wild west and many (most?) installers are able to exploit the general publics lack of knowledge.PV is a mine field
Yep. If you're on an export then big big big. It's free money over time assuming the export rate remains.Only small system here….but going to be in profit again this month with export covering leccy, gas and all standing charges. You dont need a big system, just the right one that works for you.
But if you can go big, then, go big……
they are like £30 arent theyMy electrician came round yesterday, when we did my solar extension just over a year ago he insisted I fitted rotary PV isolators, even though I had suitable DC MCB's. Yesterday he admitted he knew they wasn't really required but likes to fit them!!! That cost me money, and I also knew that I didn't need them, but I needed him.
They will soon be removed and sold on eBay, as I need to the room for more MPPT controllers![]()
I can show installs on Youtube that cost over £100k for residential. Also as I said previously my neighbour was quoted £16k for a 10 panel system, 3.68kW inverter and I believe 3kWh battery, luckily they said no, they also said no when the price magically reduced by £6k.
PV is a mine field, you really need to do your research, then do some more, get an understanding, and then shop around, check reviews for the installers preferably before getting quotes from them etc.
Oh, and without knowing the full system spec of your neighbours install, it could have been good value for money, or it could have been a rip off.
You are also better off using long established companies, so check how long they've been around. Anyone near the Kent/East Sussex boarder won't go wrong using https://www.tlgec.co.uk/ they did my original install back in 2015.
This was the system.
