A week or so back, I bought the 6" Kobo Colour and really like it. If I'm honest, the colour is so faded it's not really worth it and I don't highlight things, so I should probably have just gone with B+W, but I am already wondering if I should upgrade to a larger screen.Finally bought myself an eReader - the Kobo Libra Colour. Liking it so far.
This one is bolted in but it would be simple to replace with something suitable and quickly detachable.A tipping garden cart is incredibly useful, shame it doesn't have a tow hitch (for the lazy me!) unless the handle pops out easily?
I had one and loved it, was great for *some* chores, not so great going down (or up) out steep garden and stepsBought a little garden cart and assembled it today. Painted the metal bits with green Hammerite before putting it together and replaced the screws/bolts/washers with some made of stainless steel. It's going to be sat outside most of the time so the extra weather protection will help it last a bit longer.
I might be a special case because my lawns are raised with a retaining wall just a little higher than a standard green recycle bin. So, I just push the bin up against the wall and I can wheel the truck up to it and tip the contents straight in. You can just about see it here (taken while I was painting the truck parts!):I had one and loved it, was great for *some* chores, not so great going down (or up) out steep garden and steps
Mrs refused to used it, lol and ended up using the wheelbarrow for 99% of the jobs and subsequently selling the cart![]()
Quick update, got the new EasySMX X05 today and a quick test reveals it's rather excellent for performance and solidly built for £25 (hall effect sticks and triggers, stronger vibration motors, membrane face buttons), 1000Hz wired but comes with a 250Hz dongle too:
Lower ;latency than X10, has a ceramic aerial which they say improves stability/latency:
This is my new fav cheap but good controller now I think.
Just googled that Anker, wow it's £50 more than mine. Looks good though.@subbytna Your powerbanks look great. I've just bought an Anker 737 and the 30,000mah looks just as good. Slightly slower inpput/output (140w vs 100w) but still great and it more than makes upo for it with a larger capacity, more ports, cheaper and has the torch. Does it do pass through charging?
I love the different colour options on some of them. I can see me buying something in the future![]()
I like thatQuick update, got the new EasySMX X05 today...
They're different controllers, once uses membrane buttons on the face and the other uses tactile mechanical switches so will boil down to which you prefer. I have both and like both, I'd say for the price the X10 is one of the better mech switch controllers out there, whilst the X05 is now one of the best (if not currently the best) membrane buttoned controller given it can be had for £11 lol and beats controllers with similar buttons that cost 3x more.Thank you very much! I was looking for something to replace my (5 year old) worn out xbone controller
EDIT:
is X05 better than X10?
