I'm looking to replace the Nokia router which came with my hyperoptic package.  But would also like advice on what would be the ideal setup for my situation.  I Live in a two-floor building, and currently have the hyperoptic router upstairs which is at ground level, this is where the router has to be because it's where the connection to the fibre comes into the wall.  I currently have all of my main equipment such as my pc and everything else in the basement floor of the House and I currently run a long Ethernet cable from the router to an Asus TUF 54000, Which is currently set up as an access point and this provides Ethernet connection to my pc and other devices as well as providing Wi-Fi coverage downstairs.
The thing is I've been starting to notice problems with my Asus router and have pretty much decided that if I'm going to replace the Hyperoptic route upstairs, I might as well get a replacement for everything so that it all works seamlessly. I was looking into the ubiquity stuff, but it looks kind of pricey once adding everything up together and to be honest I'm not quite sure what components I need.
So, I'm hoping that someone with a bit more experience could suggest the equipment I need that could replace my current setup. I don't need anything extravagant as my primary devices are all connected by Ethernet which I would like to be the case, but I will still need Wi-Fi downstairs as well as upstairs where Their replacement router for the hyperoptic router will be.
Much appreciated for the help!!
