Routers: Huawei vs Zyxel?!
28 May 2003
I've just upgraded from Three wireless broadband to 250MBS Fibre from Voneus (rural area). This came with a Zyxel DX3301-TO router.
Should i stick with this, or swap to the Huawei B535-235 that i was using? The special-trick of the Huawei was its ability to hold an SIM card - unsure whether there are other differences which remain important. Priorities are speed, signal and stability - not too worried about Chinese spy-ware: nothing top secret happening here!
Ideally you should never need a SIM fail over, realistically you shouldn't need one often and you have the ongoing cost of a SIM each month with no benefit. If everything else is equal in terms of functionality vs requirements, then it comes down to personal choice.
Is giffgaff still a thing?
Do they still do free low bandwidth data?
If not, I suggest one shops around.
GiffGaff are still around.
They never offered free data.
You need to purchase either a goodybag or you pay per mb.
payg is not worth it anymore from any provider better of just getting rolling 30 day contract you can pay under £5 per month for 5gb data
Just a reminder as well on PAYG sim for example EE, you can't get 5G on those. So yep, 30 day rolling is the way to go.
