Ram Query
5 Nov 2014
Hello,
I have been looking at getting the below ram.
But it seems to be a bit confusing, its EXPO ram but the timings say 30-36-36-76 but the description seems to be saying otherwise unless I am reading it wrong
Corsair Vengeance EXPO 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit - Black (CMK32GX5M2D6000Z36)​
CMK32GX5M2D6000Z36, 6000MHz RAM Speed, CAS 36-36-36-76 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK, AMD Ryzen Tuned!
What I am looking at is 48000C36 and CMK32GX5M2D6000Z36, these both end in 36 (C36 and Z36) which I assumed means that these are CL36 instead of CL30
Does anyone have these and can confirm what they are?
Thanks
Google says they are cas36
So do some ocuk competitors who have them
It may be possible Though
That at 4800 they do cas30
But with xpm/expo enabled they do cas36
At the higher 6000 frequency
Definitely CL36 according to the manufacturer website: https://www.corsair.com/uk/en/p/mem...-s-c36-amd-expo-memory-kit-cmk32gx5m2d6000z36
Thanks to you both for taking a look.
I'll take a look at some other ram and see what they have, the other stuff is more but its XMP
I would spend slightly more for a higher quality kit of RAM and just run it at 6000 or whatever speed you were planning to use
It's guaranteed Hynix dies so it will work no questions, doesn't matter if it's XMP/EXPO or whatever.
Edit: If you want something to set and froget with minimal/no fiddling with settings though, then here
