New PC spec help pls
6 Jul 2024
Hi,
I’m new to PC and looking to build a gaming spec PC.
My budget is £1200.
I already have a monitor which is 27” 1920x1080 240hz.
Looking for a build spec advice pls.
I want a white themed build with rgb
Appreciate your recommendation
Hi,
My budget is £1200.
£1200 isn't a bad amount of cash for that res at all, but "white" will very much eat into your budget as those components tend to be much more expensive than the same things in black.
It might be doable within reason, or if you don't mind mixing black and white components a little, but ultimately you'll probably end up with weaker performance for the aesthetic.
What sort of games do you intend to play, any in particular? I ask as some hardware very much favours certain types of hardware.
Hey,
I understand that my budget will be tight how much do you think it will cost for it, because I will be able to afford it.
The games I play is valorant, Fortnite , Roblox , Minecraft and risk of rain 2 (modded )
£68 (incl. VAT)
£53 (incl. VAT)
FREE DELIVERY
£219 (incl. VAT)
£161 (incl. VAT)
are there any other cases to fit this build as I also want to look for looks.
But thanks a lot for the other specs there should work very well.
Everyone has a different preference in terms of looks, there are other options out there of course. Here's an ATX build vs the M-ATX build I listed prior, so larger form factor but a bit prettier for a full on white setup:
My basket at OcUK:
Total: £1,233.76 (includes delivery: £0.00)​
Hold in mind that you'd need to install Windows via USB yourself, but it will run without a key with minor limitations or alternatively Windows 11 keys can be found for £10.
I'd also make sure that the Freezer III fits the case, it's thicker than most coolers of its type which can sometimes be a problem.
This is amazing everything is what I am looks for except form the graphics card and the cpu.
Do you think you could find a NVIDIA graphics card.
And then will you be able to find and upgrade for the cpu that will work.
(I can spend another £200 +)
There aren't really any comparable Nvidia cards at the above price point, unfortunately they don't have anything worth buying under the 4070 but with another £200 it's just about viable:
My basket at OcUK:
Total: £1,412.80 (includes delivery: £0.00)​
I would be remiss if I failed to point out that you can also get a (none white) 4070S for £529 which would save you £50. You could also get an AMD 7900GRE for that sort of money and it would edge it out in raw performance, especially in games such as CoD Warzone, but may be weaker in media creation depending on the software that you use. You seem to be fully aware that you're paying a premium for the white theme however, and I get the love for aesthetic and the above would be an outstanding machine for 1080P gaming and probably over specified in some respects in terms of the equipment in use. At your resolution, unless you're frame chasing for esports titles a 4060ti might be better and save some cash, but it's such a piece of plap card I cannot bring myself to recommend it whatsoever.
CPU-Wise you aren't going to get an X3D out of this unless you drop to AM4 or the aforementioned 4060ti, which I'd not advise whatsoever. If you're looking for Intel it might be doable, but you're throwing away platform longevity and getting an arguably weaker gaming CPU. Sometimes you need to make sacrifices, and when doing so with the AMD AM5 platform that's an easy fix down the road as it's supported until 2027 or so whereas Intel changes socket much more frequently.
Intel alternative with a different case:
My basket at OcUK:
Total: £1,217.83 (includes delivery: £7.99)​
7800 XT Pure is a bit too expensive for me, I'd ideally want a 7900 GRE Pure for the same money.
For nvidia, you could also look at Asus Dual White for the 4070 or 4070 Super, MSI have a White version of the Ventus and Gigabyte call theirs Aero. Note that the 4070 Super uses a different power connector to the 4070 and this will either require the use of an adapter (provided in the box), which can be a bit ugly to use, or you get an ATX 3.0/PCIE 5.0 PSU instead.
Revised with 7800X3D:
My basket at OcUK:
Total: £1,453.87 (includes delivery: £0.00)​
With the case in question you can't see the power supply anyway, HSF is enough for the 7800X3D but you lose the bling factor from the Arctic Freezer III AiO, the pictures of the case shows a triple fan radiator fitted up top, that would be empty space with the Freezer 36.
Edit: You can find the Thermalright AQUA ELITE 360 WHITE V3 AiO for £50, very well reviewed bit of kit and equally blingy to the Freezer III.
These specs are amazing but what about if it was all black?
You save some money and get a fancy looking AIO back, but as mentioned earlier look up the Thermalright Aqua Elite at £50, there's also room for a chonkier triple fan GPU if you're really invested in the visual style but I've specced a double:
My basket at OcUK:
Total: £1,434.83 (includes delivery: £0.00)​
If you were open to AMD GPU's and/or less worried about aesthetic, you could jump up a performance tier also.​
Sticking with a white air cooler with more cooling ability and more bling for roughly the same money
You could also add white cable extensions to the phanteks psu.
My basket at OcUK:
Total: £34.99 (includes delivery: £0.00)​
If you need more bling the white 12v Hp cable is for you (for the 4070 super card)​
My basket at OcUK:
Total: £52.99 (includes delivery: £0.00)​
My basket at OcUK:
are there another black pc cases that would fir with this build (price range) that is glass most the way round.
or some extra fans for the pc case that you had listed.
My basket at OcUK:
Total: £149.98 (includes delivery: £0.00)​
You're generally going to be limited on how many fans are supplied in any case you buy, but I've listed a couple of other options.
The Phanteks is probably the easiest to match fans with however, as it uses the following:
My basket at OcUK:
Total: £16.94 (includes delivery: £3.99)​
So you could buy however many you need, just ensure that the DRGB controller you have is up to the job.
does the black cpu cooler come with thermal paste or should i buy some?
Any CPU heatsink will come with thermal paste, no worries there.
If you're self building, spend some time looking at RGB guides, there's a difference between ARGB, DRGB, and the controllers involved. It's usually fine, but if you mix things up enough there's a chance you can kill the lights on some of your gear. Don't overstress on it, just be calm and ask questions as you go before powering on.
thanks a lot i thought it did just needed to make sure (this is my first time building one lol)
No worries, see my above edit too.
It's basically expensive Lego, as mentioned look at guides. Plan your cable management before you build, don't be afraid of reading manuals and asking for help.
yea it is.
i have got someone who is very good at building pc's and they are going to guide me through it all
