Open folder in Terminal from Finder?
1 Nov 2007
England
Is there an app out there that lets you right click on a folder in Finder and open it with your default Terminal application? Obviously I can just use the Terminal to do it but it would save time to be able to do it from the Finder.
There’s a couple of shortcuts for Alfred where you can open a terminal window from Finder and open Finder from a terminal window. OF and OT, I think they are (I do it without even thinking what I’m typing).
Thank you! I'll have a play around. I keep forgetting about Alfred even though I have already bought it.
If you're happy to use iTerm2, then it throws options into the 'services' section, ie - right-click directory in Finder > Services > click 'New iTerm2 Tab Here' or 'New iTerm2 Window Here', opens directory in iTerm.
I just found out that the terminal I use (Warp) already does that so that is nice to know. If you've never used Warp I highly recommend you give it a go.
