Cheapest build?
28 Apr 2009
Need a cheap desktop PC for 1080p browsing, YouTube and backup storage. No gaming whatsoever. Needs at least 3 spaces for HDDS and a few SSDs 16GB RAM and a CPU that doesn't take a century to do anything. OS required. Please do your magic and get the cheapest, reliable build possible! Looked at the entry level gaming pre-builts here and they start around £800 which is just too much for what we're needing out of this. Appreciate the help, guys! :)
So:
Case
MB
RAM
CPU
PSU
Cooler
OS
Little M2 for OS
What do you use the HDD's for and how much space do they take up? You're pretty limited in case choices with your requirements, SSD's are very cheap right now and you could very likely totally swap to them while easily remaining in budget.
I'd look at a prebuilt with a Ryzen 4600G/4650G/5600G/5650G, they're often very cheap and hard to beat.
This is the best I could do.
- There are cheaper boards if you don't need WIFI.
- i5-12400 non-F is often not much more than the i3-12100.
- CPU has a usable cooler in the box.
- I wouldn't bother with 16GB of RAM at this point, especially since you might get the nerfed x16 sticks.
- Small SSDs (250/500) are rarely good value, so I just did a 1TB one.
- PSU is Seasonic built, with a 10 year warranty and a passive fan mode.
This is awkward, since most cases have only 2x max spaces for HDDs.
I could find 2 cases at OCUK that met this criteria and weren't very expensive, the Jonsbo in my spec and Kolink Levante V2 (£5 cheaper, but RGB bling).
My basket at OcUK:
Total: £631.88 (includes delivery: £11.98)​
AMD version:
My basket at OcUK:
Total: £505.93 (includes delivery: £0.00)​
You could save money by opting for an AMD 4600G but OCUK don't sell them, I think they go for around the £70 mark.
Case has room for two 3.5" HDD's, obviously it's not the greatest, but there's plenty of room to pick something you'd prefer. I've went overkill on the NvME, you could opt to drop down to a 1tb drive such as the one recommended by tetras, anything smaller becomes very poor value.
You'll never get me to spend more than £5-10 on a Windows key, I'd rather run without and deal with some minor feature loss.
okay, this is the best that I can do,
the i3 has in built graphics that will cope with 1080p browsing and watching you tube etc, no problem, it also has 4 cores 8 threads with a boost up to 4.3GHZ t,so I think that it will be pretty nippy for what it is! comes with a air cooler too and the case comes with x4 fans, I don't know how many fan headers the motherboard has, so you might have to get a fan splitter from the rainforest, as I don't think that ocuk sells any, strange but true!
according to this it has the 2 HDD bays you need, and a few SSD bays too so I presume you have drives for the system
the psu that comes with the case is over-specced in case you ever want to add a wee gpu to the system
save yourself £100 and run an unactivated win10, or win 11, or just buy a cheap key from somewhere if you simply must run an activated windows, personally, I'd just run unactivated, like I have for years!
My basket at OcUK:
Total: £677.90 (includes delivery: £0.00)​
HERE is a link to the basket to make your life easy
You will need a motherboard with at least 5 sata ports according to your first post and maybe more so I would go down the custom build as you can always add a Sats pcia card for more ports .
Case choice should be considered further depending on future needs, slots available.
Windows keys can be had for £10
Warranty is a big thing for me and new parts will give you 3 years .
If you have a spare GPU then the 12400f 6 core is a great choice for £99.
according to the ocuk page it does have an igpu take a look, here top right here
is that a mistake on ocuk behalf?
Under the star review bit at the top right it says this
BX8071512100F, 4/8 Cores / Threads, 3.30GHz Clock Speed, 4.3GHz Single Core Max Turbo, 12mb Cache, 60W TDP, Dual Channel DDR4/DDR5 Controller, Onboard Graphics: No, 3 Year Warranty
thanks for putting me straight I was only seeing the onboard grapphics, and not the ':no' part not the best text formatting there.
okay, build altered, it still comes out at under £800, added the real i3 with igpu but I've taken the OEM windows OS dvd off there to bring it down to £630 too, if he really wants cheap then get a key from somewhere else
My basket at OcUK:
Total: £630.90 (includes delivery: £11.98)​
Thanks guys for all the suggestions. Tried looking for used DELL and the like on the bay, but the cases seemed tiny and the details on how much room there was for drives or quality of the PSU were missing so didn't fancy shelling out £400 for the risk. Some of the builds here were quite close in price to a pre-built as well so ended up just getting a pre-built. Room for 4 drives in there and I can just get a PCI card with some more ports when needed. Case always has room for more SSD drives as long as you're smart with cable ties and rubber pads! :p
Enough power in this to be used as emergency rig as well should catastrophe befall the main system!
