Looking for advice
16 Jul 2024
London
Hi, looking to purchase a gaming pc which I have little knowledge about. I’m looking to spend around 1k and I already have a monitor.
I’ve come across 2 which I’m interested in if anyone can give me advice on which one to get it would be appreciated.
I play games like GTA and Eldon Ring.
PC 1 -
CPU and Memory:
  • AMD Ryzen 5-5500 processor.
  • Hex core processor.
  • Processor speed 3.6GHz with a burst speed of 4.2GHz.
  • 16 GB RAM DDR4.
Hard drive:
  • 1TB NVMEe storage.
Graphics:
  • Dedicated graphics.
  • NVIDIA RTX 40 Series GeForce RTX 4060 Ti with 8GB memory GDDR6.
PC 2 -
Graphics card
- AMD Radeon RX 6600
- 8 GB GDDR6
RAM
- 16 GB DDR4 (3600 MHz)
- 128 GB maximum installable RAM
Processor
- AMD Ryzen 7 5700X Processor
- Octa-core
- 3.4 GHz / 4.6 GHz
- 36 MB cache
Storage
1 TB SSD
Motherboard
ASUS PRIME A520M-A II
Thanks
Hi and welcome.
Could you kindly remove the link to competitors website as it's against the forum rules.
List the spec and we can comment
Also have you looked on Overclockers website at there pc ?
Hi and welcome.
Hi Micky, apologies. I’ll take a look now and also edit the post with specs. Thanks
Take a look at this pc from Overclockers which comes with a 3 year warranty..
I can beat the first system you posted and the second system has a better CPU but a worst GPU , the 4060ti is better .
With 32gb of memory and a 5600 for the same price, 4060ti and WiFi needs to be added.
CPU comes with cooler but option to add a better/quiet cooler
Have a play with the options and font forget to select the options I suggest.
My basket at OcUK:
  • 1 x OcUK Gaming Kalis - AMD Ryzen 5 5500 GeForce RTX 4060 Gaming PC (SKU: FS-1FT-OG) = £961.99
    • Case: 1 x Kolink Observatory MX Mesh ARGB Midi Tower Case - Black
    • Processor: 1 x AMD Ryzen 5 5600 Six Core 4.4GHz (Socket AM4) Processor - Retail
    • Memory: 1 x Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
    • Graphics Card: 1 x Asus GeForce RTX 4060Ti Dual V2 OC 8GB GDDR6 Graphics Card - Bulk Pack
    • M.2 Solid State Drive: 1 x WD Blue SN580 1TB SSD NVME M.2 2280 PCIe Gen4 Solid State Drive
    • WIFI Adapter: 1 x Asus USB-AC58 Wireless-AC1300 Dual-band USB Adapter
    • Operating System: 1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
Total: £961.99 (includes delivery: £0.00)​
RX 6600 is a lot slower than a 4060 Ti 8GB (TPU's database have it as 52% faster), so in the majority of newer games you'd find that the 4060 Ti PC will win. The 5700X is a much nicer CPU than a 5500, but the 5500 is sufficient for decent gameplay.
The only time I'd go "hmm..." and consider a different choice is if you play competitive (like esports) games at low settings/resolution but even then I think the 4060 Ti 8GB is very likely to be the better choice,.
