Checklist when looking at a 2nd hand car - anything to add?
18 Oct 2002
Riding my bike
Looking to get a small car for my kids to learn to drive in.
There is a Hyundai i10 locally that is insurance group 01a. 8 years old, 40k miles at a decent price.
Seller is upgrading after finishing uni, car has been in family since new.
Everything checks out on vcheck. MOT has 7 months to run. Partial service history.
I've got a sort of check list below - anything I can add?
MOT will spot stuff like worn/thin brakes, split gaitors. Emissions test would hopefully spot any gasket issues.
So my list of pokes and prods is fairly limited:
Check V5 matches VIN
Check V5 registered keeper ID
Check engine number
Check 2 keys
Locking wheel nut
Receipt
Check air-con works
Any dashboard lights
Seatbelt warnings
Electrics - windows, wipers etc
Spare tire
Road tires for uneven wear/damage
Oil level and filler cap for mayonaise
Exhasut on cold start-up
Check all lights
Engine compartment/driveway free of oil leaks
My insurance does cover me to drive another vehicle 3rd party - so I guess:
Lock to lock - check for noises
Smooth gear change
Clutch bite point and slipping
Brake straight no pulling
Check hand brake
I think that's fairly comprehensive, and given the type of car/owner then I'd suggest it's unlikely to be anything but honest.
- Worth checking is that the seller name/address match up with the V5 (presumably should be the sellers house if that's where you are meeting them)
- 2 Keys (and/or any special service keys that some makes have) - can potentially be expensive to have a 2nd coded if missing
- Locking wheel nut key
- Worth checking panel gaps, signs of paint overspray etc that may indicate it has been in a minor accident
- General cosmetic condition - if it looks ropey (dents, big scratches, untreated stone chips etc), then it's probably been treated the same. Same on the inside - if there's rips and tears on the seats, smells bad, probably had a hard life
Do a receipt also!
2 copies, fill them out the same, both of you sign both, and keep for records.
Useful if you need to prove you actually own the car, as the V5 is not proof of owership.
You've covered what I can think of...
Check bodywork for crash damage repairs.
Check tyre quality and tread depth
Renew Engine Oil
Renew Oil Filter
Check Horn Operation
Check Heater Operation
Check Air Conditioning Operation
Check Battery Levels and Condition
Check Drive Belt Condition
Check Hinges and Locks
Check Pollen Filter Function
Check Seat Belt Operation
Check Coolant
Check Screenwash
Check PAS Fluid
Check Brake Fluid
Check Tyre Depths
Check Tyre Pressures
Check Tyre Condition
Check Brake System
Check Brake Pad Wear
Check Brake Disc Wear
Check Brake Lines and Hoses Condition
Check Functionality of Lights
Check Exhaust System - If Applicable
Check Suspension
Only kidding :D
