- 13 Apr 2013
- La France
Can Williams afford him?Sainz going to Williams
Tyres weigh about 12kg per tyre - so 48kg for all 4.That's what's been reported.
I don't know I don't think 1.5kg is enough. But happy to see data saying otherwise
There's discussion that Toto knew the car was underweight as he looked unhappy when they got the 1-2, and supposedly they didn't empty the fuel tank correctly before it was weighed, which was only caught because the FIA official was suspicious about it being exactly on the weight limit. I don't think this theory that it was underweight because of tyre wear holds any merit, they knew they messed up before the finish and it was illegal the whole race.That's what's been reported.
Disagree.
He was only 1.5kg towards end of that tyre (if tyre weight is issue)
Aren't the cars 700kg is? I so that's way under 1 percent in weight.
It was a great strategy call. Whoever made it deserves credit.
I'll just have to disagree with this. But I understand the viewpoint.If he was underweight due to the tyres, it was a strategy blunder, not a great strategy call.
I don't know if it was the tyres or not and I don't think anyone does yet, but pushing the boundaries of things so far that you get dsq is a mistake, not a masterstroke.
This shouldn't cause a DSQ imo.
If the car was already under the limit that's one thing. But if it's just the tyres. That's another.
I still think if it was GRs call, it was a great call. If the team didn't check him and say "that will put us under the limit," that's on the team,and it's their mistake.
I suspect they didn't even think about it.
There should absolutely be a DSQ for an underweight car, there's no question about that and these lame excuses about tyre wear don't wash. The team already knew they wouldn't be able to pick up marbles and it would be factored into their calculations. They should have enough of a margin of safety on weight to cover the possibility of extra tyre wear on a one stopper, none of the other teams had an issue and it's never been a problem before.I'll just have to disagree with this. But I understand the viewpoint.
Hm, don't agree at all really. How often does a car get dsq due to weight?
Seems like a pretty big **** up, and if it was because of the one stop/tyre wear, it was a strategy blunder (whether it be George or the team's fault).
Yeah an underweight car should be DSQ.
Running tyres long shouldn't be able to cause a DSQ. It takes away a load of strategy options and is a further push into "f1 is boring"
Running tyres long would only cause a DSQ if you, as a team, choose to remove your own strategy options by running your weight so close to the minimum that extra wear would drop you under weight.
It was evidently an option open to the other one stoppers without dropping them under the weight limit.
Others clearly did.Yeah but you're never gonna plan for this.
This is only the second time in the last 30 years a car has been disqualified for being underweight.Yeah an underweight car should be DSQ.
As indeed it should be.Teams don’t normally take any risk around weight because it’s an instant disqualification.
Everyone works to the same set of rules, it's just something else the teams need to allow for, others did.Yeah but you're never gonna plan for this. You'd be screwed if you did anything different.
Its an odd case.
I do think its ridiculous though. That tyre wear could be the cause. I get the solutions are annoying (weigh the car without tyres) I still think it's crazy that it's happened.
Let’s be honest, if they had a full cool down lap of picking up discarded rubber I doubt wed be talking about this right now. It seems like the perfect storm. Albeit didn’t happen to the other long runners..
They haven't done one in Spa for a while because the lap is so long.Why didn’t they have a cool down lap?
