- 19 Feb 2007
- London
Running a 7800X3D in an X670E motherboard, Latest bios with 2 x 16GB of Corsair Vengeance 6000 CL30 EXPO memory, Windows 11 is fully up to date, Motherboard and GPU drivers up to date.
It's been running rock solid for the last 2+ months and today out of nowhere I started getting system restarts during gaming, No blue screen, No warnings, Just like you pressed the reset button.
I read around and most fingers are pointing at ram, To test this I set it to the DDR5 base spec of 4800 and the system is rock solid once again but if I go over 5200 then any game activity just sees an instant reboot.
What I find weird is that at its rated speed of 6000 CL30 it can pass every single memory stability test there is, Memtest, OCCT, AIDA etc... but the moment I fire up The Division 2, As an example, And walk around, Instant reboot. I tried taking out my GPU and using the onboard GPU just to be safe, Same thing happens.
Nothing in my system has changed over the last 2+ months so I'm at a loss of what it could be unless ram can degrade running at its rated speed.
Anyone encountered this before ?
