Linx Tablet drivers and BIOS downloads
I have been running windows 10 on my Linx 10 for a couple of weeks now and I am quite happy with it. Battery life seems better although I have seen some reports of issues with bluetooth but I don't use that.
I've got an image now my tablet is stuck in legacy android and it won't come out of it even when I change and save it. So I can't put windows on it.
Not sure how to get it out of legacy android.
Hi there, I'm sorry to be reviving teh thread but I just bought a linx 810B with a dead bios flash and I'm in deire need to get my hands on the bios rom. I've searched everywhere but I cant get them, and here the links are dead, can someone help me please?
Thx in advance
I bought a 2nd hand Linx 810B which wouldn't factory reset. I downloaded the recovery media above without thinking. The "About" in Windows now says Linx 8 instead of 810B and the touch screen doesn't work properly, even in the Volume+/Power boot menu. At least I know I'm on the right track but just got the wrong file. Does anyone have the 810B recovery media please?
Linx 1020 - Windows 10 2H22. I have tried to find drivers via Hardware ID, etc, etc. I cannot get the Audio and Touch Screen to work. The Linx Support website is down.
Please Help. Anyone.
Hi! I found this thread because I am looking for the chipset drivers for the Linx 14 ultraslim laptop. I looked on Wayback machine and they were at http://support.linxtablets.com/Products/Linx14US/Downloads/Linx_14US_Win10_Drivers.zip but a snapshop of that page was not saved, so the drivers are not there. I know that the built-in Realtek SD card reader does not work, so one of the drivers will be for that, but I can't find that driver separately either.
Does anyone happen to have the Linx 14 US chipset drivers, or know where I can get them?
Thanks
Thanks
I checked it but indeed snapshot of page was not saved, cant find Linx_14US_Win10_Drivers.zip file on internet so nobody saved that file to somewhere on internet.
I googled Linx 14US to find full specification, it used Apollo Lake N4200 CPU. I found old Intel 10.1.17541.8066 WHQL driver supported Apollo Lake, try it to see if it will install all drivers for your Linx laptop.
If some drivers still missing, I suggest you to download and install DriverIdentifier app to scan your Device Manager and upload your file to DriverIdentifier website, they will have complete list of latest drivers to download that matched your Linux 14US device hardware and compatible IDs.
Thanks. Some good suggestions there. I'll try them and report back.
The Intel chipset download didn't do much. However, I spent the evening working through a list of missing drivers using the DriverIdentifier tool and eventually found everything. It's slow and messy but I got there in the end. Thanks for the suggestion.
