Looking for some help and advice on the below build. I can get all this for £1583.10 if I shop around, ideal looking to spend around £1500 but can add a bit more to it.
My basket at OcUK:
Ideally looking for advice if this is worth it or if there is something else that may be better to get which gives a better if not the same performance for the same price as well as the potential if I go down the AMD route for CPU or GPU or both (mainly thinking CPU due to the recent intel issues we are aware of)
My basket at OcUK:
- 1 x Intel Core i7-14700KF (Raptor Lake-S) Socket LGA1700 Processor - Retail (SKU: PRO-INT-00801) = £359.99
- 1 x Cooler Master MasterLiquid 360L Core ARGB White All In One Liquid CPU Cooler - 360mm (SKU: HS-098-CM) = £74.99
- 1 x MSI B760 Gaming Plus WIFI (LGA 1700) DDR5 ATX Motherboard (SKU: MB-37M-MS) = £149.00
Can get this for £139.99 - 1 x Corsair Vengeance RGB 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel - White (SKU: MEM-CRS-02838) = £124.99
Can get this for £114.49 - 1 x WD Black SN850X 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T2X0E) (SKU: HD-590-WD) = £79.99
- 1 x MSI GeForce RTX 4070 SUPER Ventus 2X White OC 12GB GDDR6X PCI-Express Graphics (SKU: GRA-MSI-01574) = £629.99
Can get this for £599.99 - 1 x Cooler Master MasterBox 600 Mid Tower ATX Case - White (SKU: CAS-CLM-02622) = £104.99
Can be found for £99.98 - 1 x Kolink Regulator 850W 80 Plus Gold Gen5 Modular Power Supply (SKU: CA-07V-KK) = £109.99
The alternative would be the Seasonic Focus GX 850 for £99.98
Total: £1,633.93
SAVE 27%
£400
(incl. VAT)
£290
(incl. VAT)
£110
(incl. VAT)
FREE DELIVERY
