Caporegime
- 18 Oct 2002
Agreed, a lot of settings are just superfluous nonsense. Tweaking really helps to kick my XTX along at 4k when it's needed!
You know what, it's the 'fiddling around' part and getting things to run best as they can that I secretly and weirdly enjoy in the whole PC gaming lark. It's part of the 'hobby' aspect for me. Anyone else?
CBA setting fiddling. I just let GeForce app do the settings. Rarely need to luckily.
GeForce app...
You should be ashamed of yourself sir!
Why? It does the same job with one button. My time is more valuable than sitting there tweaking for an extra 1fps I don't need.
Anyway, doesn't matter for the 20 year old games I play. Making the most of my setup![]()
It gets it wrong a lot of the times that's why. At least on new games anyway. Plus manually tweaking is better and for me more fun![]()
I would start by assuming a 3090 will run Hogwarts at 60fps with everything on High and DLSS at every major resolution below 4k. That would be my starting point.That’s exactly what I want.
My 3090 gets there with fiddling / compromise, which I find a bit faffy. Sometimes I wonder whether the benefit of a better GPU is being able to ‘set and forget’.
I was messing around with DLSS settings and ray tracing on Hogwarts Legacy for about an hour yesterday…
Ok then it runs great! What is the impact of RT on your frames?Thanks.
With ray tracing off, everything at ultra and ‘DLSS quality’, it tends to hover at +110 with occasional dips to 90ish, so have capped it to 100fps via nvidea control panel and have left it like that. Might cap it down to 90, save on those temps!
Non-existentso whats the opinion on sept launch?
you mean over to AMD to balls up another launchbetter they don't release this year, it seems all big releases flop this year and over to you AMD. Intel are on fire
I don't think these are releasing in September, there would have been leaks.
That would probably be to AMD's advantage. There will always be some people desperate enough for an upgrade that they'll jump at the first to come along, even if something better is just a few months behind it.looks like amd (with their mediocre products) is going to beat nvidia to the market this generation
