Lenovo ThinkCentre M720q
18 Oct 2011
Hi,
So basically this is a work computer and for some reason when using any numbers there is significant input delay. I have tried another keyboard, usb port and all the other basics you would expect. Hoping someone may be able to shine some light on the situation. Cheers
Is it the same if you use the number pad (right hand side) as the keys above the letters?
This is the only similar post I could find:
But I'm very happy to say I found a fix to it. After searching for the other forum posts linked in the post, one led to a thread that explained how to fix it. However, I still don't understand why it only occurs on Lenovo. The file causing this issue is named "FMAPP.exe" I don't much about it apart from the fact it's apart of Realtek drivers. I also don't understand why it's needed, because when I disabled the process it only affected the input lag (by removing it) and nothing else...
